Question about LG WM-16100FD \ WM-16105FD Front Load Washer
LG WM-16100FD has no power
Machine is 18 months old and has been working fine since new. It has just stopped and has no power to it at all.
I have checked the supply and the fuse all of which are working fine.
What can i do to check if power is getting to the machine or is there a reset function on the machine?
If not is there an internal safety switch that might have tripped?
  • 3 Answers
SOURCE: LG washing machine
the Play/Pause button? Check if you have Child Lock on? (Hold the Pre Wash button for three seconds to turn it on or off.
Posted on Mar 14, 2007
BADBOYJAY
  • 264 Answers
SOURCE: LG Direct Drive WM-16220FD loud vibration during spin cycle
the pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
Posted on Jan 05, 2008
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
gdmisp
  • 66 Answers
SOURCE: no power
No error code like PF Some times unplug for 2 hours.to 6hours for it to reset.
Posted on Jan 15, 2009
mkh5094
  • 145 Answers
SOURCE: LG Washer trips dedicated breaker
That to me seems like an electrical problem. Every now and again you can get a bad GFCI receptacle that will constantly keep tripping. I would also see that the GFCI is properly sized for the circuit. It needs to be a 20 AMP circuit (just dedicated to the washer) and a 20AMP GFCI receptacle. The way to tell is the 1 of the three prongs of the 20AMP GFCI will be in the shape of a "T" while a 15 AMP will have 2 straight prongs and the ground prong. Hope this ws helpful, don't go spilling any money into your washer without getting that fixed first, because it doesn't seem like a washer problem.
Posted on Apr 30, 2010
I Av hoover washing machine silent pulse inverter 10kg 16000rpm and it keeps saying eq7 fault
I'm sick of this wm I rely on it for my bedridden 91 year old father it's broken down 4 times in 18 months ..I'm crying in the middle of a kitchen full of water
Aug 02, 2014 | Washing Machines
What does The "DA" on washing machine door seal rubber means ?
the issue is quite simple just go to the manufactures website and compare the part nos and part diagrams on their site eric
Jan 20, 2018 | LG Washing Machines
No Power
loose wires connection or pc board
Aug 25, 2017 | LG WM-2277HW Front Load Washer
I have an lg intellowasher 7.5kg wm1322ofd. it is not taking the conditioner down i have cleaned the drawer and the inside of the machine where the drawer goes. help! i want my clothes to smell fresh...
I hope you don't mind me saying so but often the softener dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!----------->
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this isn't the problem it could be that the water dispensing is not working correctly. It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 16, 2011 | LG WM-16100FD \ WM-16105FD Front Load...
LG WM0642H Sounds like a helicopter durning Spin
It sounds like the machine is not balancing correctly. My guess is that if you operate the machine empty (no clothes inside) that it will operate fine. If so, then the machine is not balancing correctly.
Normally an error code should come up if there is a balance issue (UE error). If this code is not coming up then the machine thinks it is balanced when it really isn't. This means that either the hall sensor is sending out incorrect data or the main board is not interpreting the data correctly. A technician should be able to ohm out the hall sensor to see if it needs replaced or the main board.
Hope this helps, please rate my solution.
Jan 06, 2009 | LG WM-2277HW Front Load Washer
Jan 05, 2008 | Washing Machines
LG WM-16100FD \ WM-16105FD Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
