Question about Epson EMP-S4 LCD Projector
Why do I have a mass of blue light specs? - Epson EMP-S4 LCD Projector
Engine light comes on not all the time.
Hard to say without car specs, howeverthe five most common reasons why Engine lights come on randomly are:
Oxygen sensor, loose/faulty gas caps, catalytic converter, mass airflow sensor, and spark plugs and wires.
Apr 14, 2015 | Cars & Trucks
What is the towing performance of a kia sportage 2ltr 4wd
Towing
Kia lists a maximum trailer towing mass (trailer plus load) of 1800 kg for the Sportage but that figure would be illegal in NSW. For light commercials (such as the Sportage) in NSW, the regulations state that the loaded trailer must not exceed 2/3s of the gross vehicle mass (GYM) of the towing vehicle. The Sportage's GVM is 1928 kg, resulting in an allowable maximum towing mass of 1292 kg. Even this figure could be beyond the Sportage's reasonable capabilities, given its sub standard handling and its overall levels of performance.
Feb 23, 2015 | 1997 Kia Sportage
What are the specs on a 2006 suzuki blvd 800?
Try here:
http://www.globalsuzuki.com/motorcycle/moto/cruiser/vz800/spec.html
Overall Length U.S. & Canada specs. : 2,395mm (94.3 in.)
Other specs. : 2,420mm (95.3 in.) Overall Width 890mm (35.0 in.) Overall Height 1,105mm (43.5 in.) Wheelbase 1,655mm (65.2 in.) Seat Height 700mm (27.6 in.) Curb Mass 269kg (593 lbs.)
Nov 17, 2014 | Suzuki Boulevard Motorcycles
What is possible problem?
An O2 sensor problem will not cause any drive related symptom. I would look at the Mass Air flow sensor and have the fuel pressure checked under a load to make sure it is within specs.
Jan 24, 2012 | 2000 Buick LeSabre
Car quits running after warming up codes that come up are po135 02 sensor heather bank 1 sensor 1 and po101 mass air flow a circert ran of performance
the o2 heater circuit won`t cause a quit running problem.however a mass air flow problem will.i would check the voltages at the connector and compare to specs and also condition of the connection.these have a problem with a small amount of dirt covering the mass sensor wire.if you clean the wire from both sides dry it and re-install this may cure your problem with the code.if the voltages are not in spec then the mass air flow sensor is defective.the code for the o2 voltages needs to be checked and the connector for corrosion if the voltages are good and connector is good to the o2 then you have a bad o2 sensor
Mar 02, 2011 | 1999 Buick LeSabre
Does not rev up when taking up a small incline,heavy noise coming from clutch. Have replaced cluth and pressure plate for the second time.The selection of gears are very hard , does not select well. Iwould...
There is a company in Northern Ireland called Exact Engineering that can convert your dual mass flywheel to single mass using a complex engineering process ending with a finely balanced guaranteed single mass product. They have a complete courir service.
You can see their website at www.exact-spec.com and contact them at info@exact-spec.com
May 03, 2009 | 2003 Jeep Liberty
96 FORD F-350 7.3 TURBO DIESEL 5 SPEED
no, it shouldnt have any looseness to it and dual mass flywheels are VERY expensive to replace, BUT yes it can be converted to a solid flywheel, check out autozone.com part number MU1989 or advanceautoparts.com part number 798, that should get you on the right path to curing your problems, i welded the two independantly turning discs of my dual mass flywheel together but i wouldnt recommend anyone doing that without the proper equipment to do so (i.e. precision lathes, cast iron welding rods, etc)
Mar 29, 2009 | 1996 Ford F350 Crew Cab
1996 F-350 7.3 TURBO DIESEL 5 SPEED MANUAL
The best thing to do is to take it to a transmission shop and ask them. They will be able to tell you if it is bad. This is the cheapest way to find out if it is bad and you can ask them how to tell for future knowledge.
1994 bmw e36 325 tds
Feb 10, 2009 | 1994 BMW 3 Series
Epson EMP-S4 LCD Projector Logo
13 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
