Question about Frigidaire FRS6HR45KS (26 cu ft) Side by Side Refrigerator
Need help fixing my fridgerator - Frigidaire FRS6HR45KS (26 cu ft) Side by Side Refrigerator
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Dec 08, 2012
Fridgerator not cold and freezer not freezing
You will need to clean the condensor coil. It is usually under the refrigerator on newer models and in the rear on older models. All you need to do is use a vacuum to clean it. Also try to leave some room behind the refrigerator, do not keep it too close to the wall. It needs to circulate the warm air it extracts.
Jul 15, 2012 | Roper Refrigerators
The fridgerator won't get cool. Freezer works just fine. But the fridgerator stopped working. The model number is LSC27931ST
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | LG Refrigerators
I have a 1 1/2 year old whilepool gold refrigerator model GS5VHAXW. In the upper left rear there is a box...I think it is some kind of damper. There is a continous popping or knocking sound and the fridge...
You are correct this box that is in the upper left corner of the fridgerator towards the rear of the machine is actually termed as a diffuser. Its basic job is to open and close letting the cold air into the refrigerator from the freezer. When you fridgerator is to cold the diffuser, also known as the damper assembly in other units, closes and when the frigerator is to warm it opens the small fins on the door letting the cold air back into the refrigerator side of the unit. There is also a control for this diffuser located in the ceiling of your fridgerator as well. Around this time of year do to the tempreture getting hot outside I do notice more diffuser's that I have to change in a week more then diffuser controls. Is this the area that is makeing that poping sound on you? Carefully remove the diffuser not breaking either of the two thermostat lines and inspect to see if you have an ice build on the inner fins of the diffuser if you do it is best to replace the diffuser itself instead of opening it or proping something on the inside of it to keep it open. If you have any further questions message me back. And please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
Rick
p.s the part number for the diffuser is W10128734
Jul 02, 2011 | Refrigerators
My fridgerator door is saying ER FF what does this mean
this is a communication error between the main computer & the display computer and they both need to be replaced to fix it. expensive job.
Jan 12, 2011 | LG Refrigerators
Hi my samsung refrigerator rb1855sw it is not keeping it cool inside and keeps making ice... i need a solution... thank you
Ok First thing would be to check that your freezer is cold. After you assure that the freezer is cold then you would have to ascertain if the fan is blowing from the freezer into the fridgerator you can do this by putting your hand over one of the vents inside the fridgerator and you should feel air flowing onto your hand if you dont then the fan willneed to be replaced. If you do have air blowing into the fridgerator then you would have a defrost problem in which you would need a multimeter to test the t-stat which is a small two wired disc like object which is usually found on one of the condensor lines if the tstat tests ok then you would test the heater please note that both of these tests are to be done with the power off and that you would be measuring continuity from one side to the other side. start with the fan and message me back if you have any further questions and please remember to rank how this opinion has helped in your appliance situation and have a great day (also note that if you are having a defrst problem or your fan is not working when you take off the rear panel inside of the freezer you will see an ice build up of some sort this buildup needs to be defrosted and there is also a drain line that you have to assure is free of ice as well )
thanks
Rick
Nov 30, 2010 | Samsung Refrigerators
The temperature of the fridge has risen to 11/12 degrees & wont come down? Freezer works fine! Any answers please
Don't know the make and model of your fridge, but most fridges have only one evap coil located in the freezer. The fridgerator compartment is cooled by a fan to blow air from the coil back into the fridgerator section. Check that the fan is working and the vents in the fridgerator are not blocked. Often the problem might be that the defrost circuit is not functioning causing ice to build up on the evap coil thus block the air flow to the fridge. If you seen any ice build up in freezer or refrigerator that could be the problem. If that is the case, then you need to have the defrost circuit troubleshot, typical failures are the heater itself or the defrost timer if you have an older model. Hope this helps you.
Oct 08, 2010 | Refrigerators
Ice on the food
why did you stop the ice maker? was it not working properly? was it over flowing or leaking? do you have a sheet of ice forming in the ice maker tray? if your ice maker was leaking then your water valve is not shutting off completely and could be leaking down on the food. if this is the case - you need to shut the water line off coming into the refrigerator and replace your water valve.
if it is frost that is forming on your food instead of ice then you should check to see if the refrigerator is defrosting properly. if the refrigerator is not defrosting properly you would also first notice that the refrigerator is not cold enough and then later that the food in the freezer eventually thawing.
May 28, 2010 | GE GSS20IEP Side by Side Refrigerator
Fridgerator no longer cooling
take off back panels in freezer. you will find ice built up. i used hair dryer ,mine was a blook of ice.
Jan 26, 2009 | Jenn-Air JCD2295HES Side by Side...
Leaking water inside fridgerator
You need to manually defrost then let sit over night .Pour warm water down the drain hole if does not go down fast than you will need to clean drain tube out with wire start at the rear of the unit and there will be a drain tube going in the drip pan good luck :)
Sep 10, 2008 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Refridgerator water dispenser doesn't work.
Thanks for all the answers for this problem that seems to happen to many different fridgerators. my fridge just needed to be on for 12 hours before everything begins working.
Jul 24, 2008 | Refrigerators
Frigidaire FRS6HR45KS (26 cu ft) Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
