Question about Frigidaire FSC23F7D Side by Side Refrigerator
Frigidaire side by side not dispensing ice
Ice Dispencer on WP rrefrigerator model ED5GVEXVD07 not dispensing ice...Ice maker is working fine, auger works fine, chute and gate not frozen or clogged....I believe the problem is with the gate on the near end of dispenser not opening....At the rear of the freezer, there is a solenoid activated plastic part with a square hole that activates up and down to operate the spring loaded wire that controls this gate...Spring is OK and by holding the button on the side of interior freezer door, I was able to observe the solenoid activating the square holed plastic part up and down when ice dispenser was activated... I have removed and reinserted the ice container several times, cleaned the rails etc, but still cannot get the thing to dispense ice either crushed or cubed...I suspect the gate isnt working for some reason or another..Suggestions appreciated.
  • J.R. Odum
    J.R. Odum Dec 10, 2012
    I screwed up on the make and model...First Post thingie and my computerally challenged brain...The make and mode is a Wirlpool, purchased from Lowes and is about a year and half old...WP rrefrigerator model ED5GVEXVD07..Could it be the solenoid isnt quite strong enough to fully retract the gate via the springloaded wire???
dmftrucker
  • 1922 Answers
SOURCE: Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Posted on Aug 23, 2009
SOURCE: Ice Maker offers Cubes or Crushed
sell it
Posted on Aug 12, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
SOURCE: freezer wont dispense cubes, only crushed ice
I had this same problem for a few days. I opened the door & played with the ice dispenser hole and it ended up working again
Posted on Jan 17, 2009
  • 441 Answers
SOURCE: Frigidaire Model GLHS68EGSB2, ice maker will only
You need to take out the ice bucket, empty it, let the bucket sit in the sink for a few hours. Ice builds up in the crushing blades and jams them, let all the ice melt out of it and it will be fine
Posted on Oct 27, 2009
Have a Side by Side Frigidaire Ice MAKER and water is OK, Ice Dispenser thru the door just stopped working. I bench tested both the solenoid and the auger motor with 120Vac and both work fine.
Did you check to see if your ice maker is working at all? What are you taking voltage readings at augur motor if it is working? - does not make sense unless you have all sorts of time on your hands. Test water solenoid for ice maker?Need parts? Go to link Search Over 2 1 Million Appliance Parts
Aug 27, 2017 | Frigidaire Washing Machines
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
Model FRS26R4AB5 Frigidaire ice maker. Unit makes ice but will not dispense. When engaging in-door dispenser switch, I can hear the motor come on, but the auger does not move. This occurs even with the...
pull the ice tray out, you will see a silver thing in the back that turns the auger,, push the ice dispense button ( you might have to hold the door switch in) and see if it turns, if it does you need to replace your ice tray,, if it doesn't you will need to replace the solenoid or the motor itself
Jan 24, 2011 | Frigidaire FRS26R4A Side by Side...
Ice dispencer not dispensing ice
Ouch, if your auger won't turn, pull out the ice tray unit. At the back you will see the gear for the auger unit. Try and move it, both clockwise and counterclockwise. If it won't turn - you have a motor problem and needs replacement. If it turns too freely, then you have a weak motor and it will not push the ice.
Aug 21, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker will not dispense ice
your gpoing to have to thaw out the pan that has all the ice in it the the auger will work
May 23, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice cube button is lite but the only dipenses crushed ice
We have had this problem on occasion. The lever up in the ice dispencer gets jammed with frost and ice. If you remove the ice bucket/auger and let it thaw or just rinse it with water and dry it. Give it a try. -Matt
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker makes ice, but won't dispense.
if you hear a click when the actuator is depressed the swt is ok remove ice bin and try rotating auger mtr by hand if you can't the auger motor is frozen, you can remove the whole auger asm and let it thaw out and dry out for a few days
Dec 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FSC23F7D Side by Side Refrigerator Logo
391 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
