Question about Frigidaire FRS6HR45KS (26 cu ft) Side by Side Refrigerator
My fridgerator is not cooling, when i set it to 8 it drops back to 4
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Does the compressor run?
Posted on Dec 08, 2012
Freezer is cooling but the fridgerator is not?
check the radiator on the back of the fridge, check and see if theres dust ,if so cleane off the dust and make sure the fridge has 1 to 2 inches between the wall so it can breath. that might help.
Jun 12, 2012 | Refrigerators
The fridgerator won't get cool. Freezer works just fine. But the fridgerator stopped working. The model number is LSC27931ST
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | LG Refrigerators
The temperature of the fridge has risen to 11/12 degrees & wont come down? Freezer works fine! Any answers please
Don't know the make and model of your fridge, but most fridges have only one evap coil located in the freezer. The fridgerator compartment is cooled by a fan to blow air from the coil back into the fridgerator section. Check that the fan is working and the vents in the fridgerator are not blocked. Often the problem might be that the defrost circuit is not functioning causing ice to build up on the evap coil thus block the air flow to the fridge. If you seen any ice build up in freezer or refrigerator that could be the problem. If that is the case, then you need to have the defrost circuit troubleshot, typical failures are the heater itself or the defrost timer if you have an older model. Hope this helps you.
Oct 08, 2010 | Refrigerators
My 2 door fridge - the lights are on but does not work means does not get cold. No humming noise either. For a while I was resetting the temp to off and back to 3 or 4 then it starts working for 2-8...
So when the thermostat settting was changed the compressor worked but did it cool? if not switch off the compressor for about 8 hours and then switch on with the thermostat set to normal cooling, if the compressor cools the watch the progress further , if cooling drops the next day check the auto defrostt timer.
if there is no cooling then the compressor or gas pressure is low.
Sep 24, 2010 | Whirlpool Refrigerators
Refrigerator temperature will not stay in 30 degree range for any period of time. It seems to repeatedly go up to 55 or 60 degrees and then drop back down to 38 degrees for a bit. In contrast, the freezer...
have you done a continuity test on the t-stat and the heater also when you did replace the fan did you assure that you defrosted the airport holes that go from the freezer to the fridge area lastly if the t-stat and the heater check out to be working properly then you might have a sensor problem but first check out the tstat this is usually the first thing that goes on fridgerators please remember to rank how this opinion helped in your appliance situation and if i can aswer anything futher please message me back thank you again
rickead1
Sep 02, 2010 | Samsung RS2630WW Side by Side Refrigerator
My Kenmore elite mini fridge turns on and the light on the inside comes on and the compressor is running and is pretty hot but the fridge is not getting slightly cool, what would cause this and how could i...
We had small fridge in our RV Travel Trailer.It would run to the tempure control setting,then it would shut off.Check it out,set it up high,then as is cools in about 12-24 hours then set it to 3-4 setting that should keep fridge Kool.Or you may need some fridgerant reinstall.Call your local repair man to quotes to recharge/fridge.Hope this help you out.
Aug 08, 2010 | Microwave Ovens
My GE fridgerator will not make ice and will not
Open the door and depress the door/light switch,the evaporator fan motor should run.If it doesn't make sure the thermostat is set cold enough.If it is,you could have a bad defrost timer.they are fairly inexpensive and easy to replace.Every day the compressor and evap,motor shut down for @ 10 min and the heaters are turned on to defrost the evaporator to prevent ice buildup.You could have a compressor problem also but lets hope not.
May 31, 2010 | Refrigerators
Installing distibitor 1997 5.7vortec
with # 1 piston (front piston on drivers side) on tdc compression stroke place distributor in pointing at the front of the drivers front tire as it drops in it should point roughly at the # 1 piston as it rotates clockwise as it drops in , the cam gears have to mesh so dont force it . if it wont drop into place try a small bump of the starter while applying light pressure down on the dist.it should drop into place and then lock it down a bit . get #1 piston back on tdc compression stroke make sure the power wire is off the dist . the big red 1..you dont want it having spark yet. if it goes into place then set your cap and wires back in and time it with timing light .remove vacum hose from vacum can on side of dist and plug the hose off then use timing light and set to what factory says , usually between 4-8 degrees btdc. 1-3-5-7 piston numbers front to back drivers side ///// 2-4-6-8 front to back on pass side firing order is 1-8-4-3-6-5-7-2 and the dist should have #1 pointing at the drivers front corner of engine. start # 1 plug wire there and work clockwise next spot clockwise on dist is #8 plug wire and so on.. good luck
Nov 19, 2009 | 1997 Chevrolet K1500
Fridgerator no longer cooling
take off back panels in freezer. you will find ice built up. i used hair dryer ,mine was a blook of ice.
Jan 26, 2009 | Jenn-Air JCD2295HES Side by Side...
Frigidaire FRS6HR45KS (26 cu ft) Side by Side Refrigerator Logo
319 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
