Miele W701 drum stopped working
Machine working fine until the other day. Drum does not rotate during washing cycle or spin. Water comes in fine, heats up and drains away. Had machine since new over 20 years ago - is it worth repairing?
  • Helen Aldis Dec 10, 2012
    Additional information - water pump seems ok and drain filter cleaned out. Power ok to machine and door opens from control panel. Cold fill but machine heats up water as normal when going through washing cycle and drains when should. Only problem seems to be that drum does not go round during washing cycle or during spin cycle.
    New Friend:
Hi, I have the same problem as you, same washing machine model, I suspect the problem lies with the electronic control box, the electrolytic capacitors probably dried up from old age and need replacing. The control box is behind the front large door / panel of the machine (not the drum door); in order to open the large door / panel you have to remove the two screws near the detergent drawer, three screws near the entrance of the drum (the three that are covered when the door is closed, and with a screwdriver underneath the machine, right under the wash filter door, there is a release mechanism, push it down to open the door (there are hinges on the other side, so it won't fall off). The control box is the white box held with two screws you can see at 2:23 in the following video I found on YouTube (it's the first video that comes up on Google when you search for Miele W701, in this case it's an Italian model machine, but internally it's the same thing everywhere). Electrolytic capacitors have acid inside and it's perfectly normal for them to dry up over time, lasting twenty years is very good, but all of them dry up sooner or later. The pcb is fairly large and the circuits well spaced and thus it should be fairly doable for anyone with a soldering iron and proper solder (and soldering skills) to replace the electrolytic capacitors with new ones of the same rating (the rating is written on each capacitor). Or you can try to see if you can find a replacement control box from Miele. http://www.youtube.com/watch?v=q3nnSUxQWJI Cheers.
Posted on Jan 28, 2013
  • tpi2007 Jan 28, 2013
    I just found this site which might be of interest for you (and for me!), provided you can send them the pcb, they willl repair it for you (pretty affordable, by the way, not that capacitors aren't cheap, they are, but it still takes time to do the job yourself and srouce the adequate capacitors, so this seems like a pretty good deal:http://youfixit.eu/en/index.html
  • Anonymous Mar 03, 2017
    Yes!!! I have replaced all the electrolytic capasitors on the electronic control box, and it seems to work better then ever :-).
Soulvisitor
  • 1113 Answers
SOURCE: DRUM HAS STOPPED SPINNING
Well, I failed to find your product but found close and I've read the manual and can see no sign of anything being able to be presed that would stop motor operating in its wash cycles, I take it that you have totally drained/removed clothing and let machine get to normal start position, and done the standard disconnect from power, and plug it back in and test again and make sure no flashing lights are present and door is locking correctly
Possibility exists that your balance switch is faulty I'd look at that if not then Either motor is dead or control board is faulty
If you know your way around electricity then you could test if power is being supplied to motor.
As for the count losing 10 mins then thats pointing to control board fault (quite possible due to operations panel being operated)
Link to Manuals I read
http://www.boschappliances.com.au/content.asp?keyword=wfo&action=search&document_id=17&x=38&y=13
Posted on Nov 25, 2007
SOURCE: Bosch WFL2450 Washing Machine wont spin cycle
Hi there, this problem sounds as though the carbon brushes are needing replaced or infact just needing to be cleaned of dust or dirt. Its very common for the brushes to be covered in dust and fibres. Im not sure where the brushes will be on this model but I hope this helps you in someway.
Posted on Sep 24, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
SOURCE: No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Posted on Jun 02, 2009
barkencoa
  • 3463 Answers
SOURCE: Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Posted on Jan 16, 2010
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Out of balance when spin starts
Hi dear. Your machine needs new shock absorbers and drum tension springs replacement. I can advise to contact your local Miele center. Thanks.
Apr 01, 2016 | Miele Washing Machines
My miele wt945s takes in some water after final spin so clothes at bottom of the drum end up wet. Can I stop this happening
There is a problem with the programming of the control board if this is occurring.
All you can do is turn off the water to the machine at the end of the full cycle and then run the spin cycle again to dry out the clothes. Then no water can enter the wash drum.
Otherwise you would need to turn off the water each time before the spin cycle concluded and thus before the machine began adding water again.
Dec 08, 2015 | Miele Washing Machines
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Frigidare gltf1670as
You likely have a broken or slipped drive belt or broken spring on the belt take up arm on the drum. Appliance Parts.com has a lot of DIY instructions on how to get at the belt and make repairs.
Jan 23, 2018 | Washing Machines
Miele w1113. Washer drum won't spin during wash cycle
I assume you are saying the machine is working except the drums not turning? - you need to see if the belt has come off because thats what i would check first if you hear the motor start/stop after it fills up with water.
May 30, 2011 | Miele Touchtronic W1113 Washing Machine
Drum doesn't really rotate on wash cycle.
No solution, but I have the same or similar problem - bootom agitaor works, top doesn't. Also softner spots clothes during spin cycle - help - I can't afford a repairman!
May 17, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
DRUM NOT SPINNING
Disconnect your washer's plug for 5 minutes or more from the wall socket. Plug in. Press "end of cycle" button for over 5 seconds, the child lock comes off.
Press it again and the child lock comes on................ If this does not work, try the pre-wash button likewise.
Nov 22, 2007 | Bosch Exxcel WFO 2264 Front Load Washer
Washing Machines Logo
419 people viewed this question
Top Washing Machines Experts
