Question about net10.com
I currently have a LG900G, the signal strength has been extremely weak since I've had it. I have not been able to find a solution to this problem as it causes dropped calls and sometimes does regi
Hello Dennis,
I had a similar problem with an LG 800 phone I had to get a "Wilson Electronics 815225 Sleek Booster Single" for it to use the phone in the basement apartment where I live and it works great I get three to four bars now. However it costs about 80.00 at Walmart, and Amazon, I couldn't use the reception booster while away from home though so I found out that Samsung, phones work much better here and most other areas as well. I hope this helps
Posted on Dec 10, 2012
My wifi doesn't work.
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 08, 2012 | Computers & Internet
No input 2 signal
The connections bad.... try rewiring the one for signal 2 or if its making a good connection... look for a weak spot in wire... that helped me when i couldn't figure out wiring
Aug 28, 2012 | Cars & Trucks
Internet connection lost every 30 minutes
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
May 22, 2012 | D-Link Xtreme N DIR-655 Wireless Router
My wireless network isn't working
Apr 19, 2012 | Toshiba Satellite Pro L300 Notebook
Router connection
The problem is not the antenna.
Apr 13, 2012 | Computers & Internet
Dlink dsm 330 keeps losing contact with pc
Mar 03, 2012 | Computers & Internet
Sanyo mod dp19241-no pic 'Digital channel signal strength is low' is on screen
Hello
As the set reports, the strength of the digital signal it gets may be weak. An other possibility is the fault with its digital tuner itself. Check the digital signas strength first. You can contact your cable provider, and ask them to check the signal strength at your premises's cable end. If it found satisfactory, there is no other way than replacing the digital tuner of your TV.
It is a skilled work, and should be done either by any expereinced serivce technician or by the authorised service center for Sanyo at your town. OK.
Oct 23, 2011 | Televison & Video
I have an LG900G and suddenly the screen is totally green. Someone said to take out the battery and hold down the "On" button for 20 seconds to "reset it. But this isn't working....
I'm having the same problem! This is the second LG900G phoen I've had. The first one would randomly turn off & then not turn back on unless it was plugged into a charger (even when it was fullly charged). Luckily, Net10 replaced it. The replacement phone was less then 10 days old when it started turning green. Did you ever have any luck at finding a solution? I really don't want to have to call the company and go without the phone as I wait for a replacement if their are other solutions. Thanks!
Aug 19, 2011 | Cell Phones
I've had a Spotstar #5 Radio for Home Use since
it could be the signal has been down graded. new laws on signal and strengths have been coming in over the fear of wave format. the best way to gain a weak signal is a booster of some kind to bring in the weak signals, hope this helps.
Jun 16, 2017 | Sirius Sportster 5 Satellite Radio...
Acer Aspire One D250 - Weak network signal strength with Broadcom 802.11g adaptor
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
Dec 26, 2009 | Acer Aspire One PC Notebook
net10.com Logo
154 people viewed this question
Top net10.com Computers & Internet Experts
adam adms
adam adms
Randy Handy
Are you a net10.com Computer and Internet Expert? Answer questions, earn points and help others
