Question about Maytag Dryers
Maytag model mde9700ayw dryer how to access heating element
How do i remove the front of this dryer
  • Maytag Master
  • 8,220 Answers
Haven't worked on one of these yet but it is pretty much like the duet dryer on my blog page:
https://www.youtube.com/watch?feature=player_embedded&v=APlWrIcP94g
Posted on Dec 08, 2012
SOURCE: Maytag frontload dryer MDE9700AYW
take the door off. take the front panel off. take the belt off the tumbler. take the tumbler out. you should see the roller. everything is held with regular phillips head screws.
Posted on Mar 07, 2008
SOURCE: removing front panel on kenmore dryer
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
Posted on Mar 10, 2008
  • 1028 Answers
SOURCE: how to replace heating element, kenmore model 110.60912990
lint screen in door ? remove bottom apnel ..top lint screen remove rear panel both cases ckd thermal fuse on top end also
Posted on Jul 05, 2008
MNTECH
  • 1543 Answers
SOURCE: maytag dryer model lde312 runs
Remove the two phillips screws in the dryer front at ankle hight. Pull front toward you and unhook from top. Leave wires connected. Heating element visible at lower right.
Posted on Dec 01, 2008
Sea Breeze
  • 4654 Answers
SOURCE: user manual for Maytag DE313 Series 107
(Click below for user manual)
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=RF262LXSB0&siteCd=WHRCOM
The age of your dryer I'm not sure, The elements for your dryer can be found below, go to my web-page and enter the model DE313 into search feature and you will get pictures of the parts. The element part# is Y313538 (click link below)
http://servicepartstec.blogspot.com/
If you need help, just let me know,Thanks,Sea Breeze
Posted on Mar 23, 2009
Maytag dryer MDE9700 AYW We replaced the dryer heating element and the dryer still don't heat can anyone help me figure what parts I need
http://www.appliancepartspros.com/01-blower-heater-parts-for-maytag-mde9700ayw.html 14 and 15
Jan 12, 2016 | Maytag Dryers
The heating element connects to a thermal fuse and then to a thermostat. The thermal fuse may be blown. There is no outward sign of failure http://www.appliancepartspros.com/01-blower-heater-parts-for-maytag-mde9700ayw.html
14 and 15 on the diagram
Maytag epic front load electric dryer is turning but only blowing cold air ?
Unplug dryer. Remove heater element, and inspect element for damage. Use an ohm meter to check for continuity. Should have some resistance. Should not be open or short.
Oct 18, 2013 | Maytag MDE9700AYW Neptune 174 Electric...
It is a model no mde9700ayw and it stops and gives the code hE
This error means there is an issue with with the heating portion of the dryer. Could be the thermistor, or the element, or the control board. You have to use a multimeter to troubleshoot the problem. You unplug the dryer, disconnect the element and use an ohmmeter to test the element for continuity.
The element should be between 10 and 50 ohms if it's good. The thermistor should be around 10,000 ohms at room temperature and if both check good, replace the control board.
Hope this helps.
Jul 20, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
How do you replace the heating element in a maytag neptune dryer model mde9700ayw
I am about to find out! But according to Tim Mereno, which by the way sells the part for 65. said it is not really to difficult! I will let you know.
Jun 07, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
I have a maytag dryer model # mde308dayw. How do you access the heating element to replace it?
remove 2 screws on the front cover by the floor lift bottom of front cover outward toward you and remove ,then undo wires at door switch,then remove drum belt and drum,then the heater element is at the right side near the base in a duct assembly
May 04, 2011 | Maytag MDE308DAYW Electric Dryer
I need to know how you would replace the heating element on dryer model Maytag MDE9700AYW.
First you take off the top panel two screws then four qr five screws to take off console then four screws top of front panel and two scews just below your filter on front panel and you have access to your element
Apr 29, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Dyer model # MDE9700AYW wont heat it blows cold air
Ohm out the thermal fuse, if it is ok, then you can ohm out the heating element, be sure to visually check the element as well becqause it could just be shorted out internally giving you a reading, but first and foremost check your voltages be sure you are getting 240 across the outer plug spades and 120 volts from left to common and right to common, unplug this thing before you get into the element area or you could end up with a smokin fro !
Apr 07, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag dryer mde9700ayw
I have the same problem--it is the heating element. Bad news is they don't make the part anymore. The solution from maytag.com is to buy a new one and they will reimburse you 15%...not a very good solution considering how much this one cost and the amount of years it has been used.
If you find a place that sells the heating element please post!
Aug 31, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune Thermal Fuse Location?
Yes, I just changed thermal fuse on the same model . . . take off the front door, the front panel and there it is; attached to the vent tube with a flimsy bracket
Mar 30, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Dryers Logo
189 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
