Question about Canon PowerShot S5 IS Digital Camera
My aperture or lens isn't opening - can't take a picture. It worked fine a couple of weeks ago and when I tried to use it this week it was a no go.
  • Canon Master
  • 4,738 Answers
Aperture and lens are two different things. If you mean the camera is taking black pictures (something common for the S5), then see this link.
But if you mean that the lens isn't extending properly, then see this video:
Posted on Dec 10, 2012
3 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: When I open the lens... A menu page comes up...
If you're seeing black or distorted images both on the LCD and on the recorded pictures, then this might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info: http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 16, 2007
  • 11967 Answers
SOURCE: lens error canon powershot sd1100 is
Apparently, you missed some sand and it just took a while to work its evil way into the works of your camera.
Posted on Aug 12, 2009
DSLR says lens not attached
Hey there,
It sounds like your problem is related to the aperture setting on your lens. The aperture ring should be set to the smallest aperture usually f22 when attaching these older lens. Most lens aperture rings will provide a locking mechanism for that ring on the lens.
The aperture would be then set through the camera, not on the lens. Also some nikons have a lens preset on their menu, where you can inform the camera which lens is attached. Most of the older lens lack any terminal points for communicating with the camera automatically, therefore you will have to fill in the data manually to get better functionality out of the lens camera combo.
Sep 25, 2013 | Nikon D3200 24.2 MP CMOS Digital SLR with...
I installed a Craftsman garage door a couple of weeks ago and all of a sudden it keeps opening by it's self. It is model #139.53918D what is causing this?
Make sure the door isn't closing too far. This will cause it to open. Your opener comes with a warranty. Call Sears repair.
Sep 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Telephoto AF Nikkor 85mm f/1.8D Autofocus Lens on Nikon D200 camera body, and I've been using it for a few months with no problems. I love the lens. But a week ago I was in the middle of...
You may want to check what the aperture ring is set at on your 85mm. Nikon SLRs for most purposes, require that the f-stop on the lenses be set at the minimum aperture number, ie f-16,22,32. This is so the camera has the full range of the aperture to control it properly. Most if not all lenses for Nikon have a small button, usually marked with orange, to lock the aperture ring at that setting
Jan 11, 2010 | Cameras
Lens error canon powershot sd1100 is
Aug 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
I've had my camera for about 3 years now and have never had any problems until a couple of weeks ago. When I turned the camera on, it forced me to reset date/time and would occasionally show aperture 00...
Try getting new trusted brand batteries like duracell, And also if it forces you to change the D/T just change it. Also try getting a new memory card. (trusted brand). If none of this works then there might be a prob. Maybe someone dropped it. Try asking the company 2.
Hope this helps
Jun 26, 2009 | Canon Digital Rebel XT / EOS 350D Body...
I think I messed something up on my lens.
You are correct that the switch locks the aperture. In order for your camera to function correctly in the auto-focus mode you must lock the aperture to the smallest opening (largest number such as f22). The switch has two positions. The position where the switch is lined up with the orange line is the locked position. When the lens functions properly and on the camera, the lens aperture is forced wide open by a pin on the camera body pushing a lever on the lens that opens the aperture. As part of the sequence when you push the shutter button, the camera releases its pressure on the spring-loaded lever on the lens, allowing the aperture to close to the setting that the "computer" has determined as correct. You will find this lever on the outside of the black ring that surrounds the rear lens element. With the lens removed, find the lever and make sure that with the lens set to the f22, sliding the lever counter-clockwise against the slight spring tension, the aperture opens wide and returns to f22 when released. If this is not the case, the problem is in the lens. If this works, then the problem is either in your camera body or in the alignment between the body and lens. If this does not get you on the right track, let me know what you find and we will proceed from there.
Nov 23, 2008 | Nikon Cameras
Subject too dark in viewfinder
It sounds like the infamous aperture control problem. I had mine fixed by this place:
http://www.garryscamera.com/
They had it for a couple of weeks, and when I got it back it worked perfectly.
Mar 04, 2008 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Darkened Images
Sounds as if your diaphragm may be sticking due to either the camera or the lens. Look at the back of the lens and work the small tab with the aperture ring set to f32 (or 22). See if the tab moves smoothly but with resistance from a spring, or if it sticks or moves roughly. If it does this with other lenses too, another possibility is the aperture lever on the camera. Mount the lens and set it for f22 or so and use your depth of field preview to see if the lens is stopping down smoothly. In either case it may need professional repair.
Nov 02, 2007 | Sigma APO 70-200mm f/2.8 EX DG HSM Lens
Pictures appearing black- olympus FE 170
You checked the obvious, lens cover? (sorry had to ask) any grinding noises when you take a picture or focus\zoom?
Aug 26, 2007 | Olympus FE-170 Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
201 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
