Question about ASUS K40IJ Laptop Charger (1300742LMD0017838)
My asus k40ij is not charging
It was working fine earlier, but then when the battery was running low, I plugged it the charger but it wont work. please help. thanks
camille zar
  • 95 Answers
SOURCE: Asus Eee PC 900 which has a weird problem
hello
The problem you are facing is a very common problem.
The memory dumping statement show that you RAM is dying and soon it will be dead.
Replacing the RAM would solve the problem.
Thank you
Posted on Aug 07, 2009
VargheseAcer
  • 142 Answers
SOURCE: Asus eee 900ah Plugged in a charger and battery is
I am not sure what the exact issue happened to ypur computer, if you are not able to turn on the computer then remove the battery and AC adapter from the laptop, not press and hold the power button for 20 sec( No batteery and Adapter), now connect the power cable back to laptop and then try to turn on the computer, still not able to turn on the computer then you consult with local tech or with wantty
Posted on Nov 21, 2009
apacheadmira
  • 55 Answers
SOURCE: asus model k40IJ. playing movie in media player no
First you have check no yor BIOS that your internal sound card is enabled or disabled and then check on your device whether it's being detected
If your system detects it then you need drivers for the sound card
here is the link if you are using Xp
http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Jan 02, 2010
  • 20 Answers
SOURCE: asus 1005ha netbook wont turn on
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena95
Posted on Jan 03, 2010
  • 20 Answers
SOURCE: My eee pc wont recognize that it is plugged in.
Usualy this is a battery fault.
If the laptop remains on ac mode without battery try to replace the battery.
Posted on Mar 10, 2010
My ASUS K52 battery is at 58% and not charging why ?
Is this an ASUS charger and battery? Some ASUS laptops will not charge after a certain charge is reached, but it's usually in the 95-100% range to prevent overcharging.
If you bought an aftermarket charger, it may very well not have the amperage to charge while running the laptop.
Feb 13, 2015 | ASUS 156 K52 Notebook (AAC4001K52DRA1)
Asus Memo Pad HD 7 won't turn on or charge.
1. how old is your tablet 2. have you tried another charger such as a phone charger. My blackberry charger works fine for my tablet. Also with your tablet you should have had a usb cable that connected from mini usb to the asus plug in transformer.
Jul 20, 2014 | ASUS MeMO Pad HD 7
New batteries wont charge???.
Possibly the charger is faulty.
Apr 15, 2014 | Jet 3 Ultra Power Chair
Won't Charge
If it's not a recognized charger it'll stop charging the battery and try to run on the charger alone. If the peak draw of the laptop is higher than the charger output, it'll go right back off.
Try removing the battery and see if it'll boot on the charger alone.
Apr 01, 2014 | ASUS Q200e Touchscreen Notebook
Our 2008 dodge charger wont start,and the radio wont work,checked all fuses/circuit breakers/relays,all good,but it still won't start-cam somebody-PLEASE help me???
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 05, 2012 | 2008 Dodge Charger
My laptop wont charge so i brought a new charger but it still wont work.
It could be the battery... they tend to wear out over time. If you run the laptop with the charger plugged in, it works fine, right? It just won't hold the charge?
Aug 31, 2010 | HP Compaq Presario CQ61420us Notebook
My samsung rant wont charge. it charged yesterday but today after plugging it into the charger the Samsung name lights up and then it says "low battery please charge" but it wont charge, i did drop it in...
Phone not charging.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 10, 2010 | Cell Phones
ASUS K40IJ Laptop Charger (1300742LMD0017838) Logo
149 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
