Can I use a 15A/32V fuse to replace a blown 15A/250V fuse
  • Audio Player... Master
  • 5,455 Answers
No! Unless you have read it wrong and it should be 320V. You can go higher than 250 volts but not lower. And you can go lower say to 10A and say up to 16 or 20A, though you should stay around 15A to be safe. If you do fit a 10A fuse at 250 volt and it blows straight away then it won't be the fuse that is faulty, but something inside the amp that has gone. As fitting even a 15A 250V will do the same. A 32 volt fuse in the mains section will burn out in a fraction of a second.
Posted on Dec 09, 2012
3 Suggested Answers
  • 733 Answers
SOURCE: I replaced blown fuse with AUSTRALUX DA205-2A 2A
It's drawing too much current, make sure you install the excact replacement or an alternative approved replacement. Other than that, if it's still blowing the fuse than theres an overcurrent condition in the system...meaning a short.
Posted on Nov 21, 2009
Grubhead
  • 5455 Answers
SOURCE: T12.5L 250V fuse for carver amp
Yes T1 stands for fuse One. The fuse is a 2.5amp at 250volts. The only thing you need to work out now is if it's a Quick blow or Slow Blow type. Sometimes you can still see the remains of the wire that's gone on the old one. This is your best clue to it. If it is a single wire it's a Quick, if you can see a coil then it's the other.
If in doubt use a Quick blow type.
Posted on Nov 23, 2009
I have an Avanti gfit motorised t/mill.It has blown a fuse that is located on the circuit board.the fuse is rated 250volt/10amp.Where can I buy some more fuses, and how do I get a service technician to...
A sudden load can be enough to cause the fuse to blow rather than a short. Replace the fuse either with a 250v 10A Slow blw fuse or us a 250v 15A standard fuse. If it still blows then there is a definite fault. Motor Loading from lack of Lubrication etc.
Or a wiring short. Fuses are available from many suppliers. The shape of the fuse being used and how it clips into the board will be import and. Take a sample or an iPhone photo with you.
Feb 26, 2015 | Avanti Exercise & Fitness
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
The fuse in my microwave oven is burnt. It was rated 15A 125V. Can I replace it with a 15A 250V fuse? What are the pros and cons? I don't want to risk damaging the appliance.
Yes, if it will fit in the holder tightly... you can always change a low voltage with a higher voltage but never take out a 250 and install a 125...
heatman101
Dec 24, 2010 | Microwave Ovens
My LG REFRIGERATOR stopped working all together, no lights, nothing is working at all. Checked the plug and it works fine.
ctmarrero was correct! There are two fuses on the mother board, and the larger one was blown. I took off the mother board (easy) and soldered off the old fuse and replaced it with a new fuse holder that will allow me to replace it next time without soldering. The fuse is a 250V 15A. This cost me less than $5. The new "PCB Assembly Main" EAP3533829" board cost $181.82 on easyappliance parts.com. Bad design by LG, should have had a fuse holder so it can be replaced easily.....
Oct 30, 2010 | LG LSC26905TT Side by Side Refrigerator
I have a blown internal fuse on my JennAir M170b microwave. The fuse holder says 250V, 15A fuse, but the fuse that was in there is a 125V, 15A fuse. The micro plugs into a normal 110V circuit. Which type...
The information on the fuse is the maximum rating. The holder may not match the rating.
The 'A' is the very important part of the size. You will need a 15 Amp fuse. The best fuse to use is 'ceramic'. You can find them at Radio Shack in the back of the store there are drawers with electrical parts.
15 Amp ceramic
Jun 10, 2010 | Jenn-Air M170 Microwave Oven
Looking for a replacment fuse #T3.15AL 250V
The cheapest place I have found is amazon. here:
QUALITY USA brand fuses Set of 5 pieces T3 15AL250V T3 15A 250V T3 15L250V... (you can search from another sellers, but this one had most positive reviews). I hope this was helpful. cheers
Jun 07, 2009 | Goldstar DH504EL Dehumidifier
Fuse T1.6L250V
The fuse which you have used is of correct rating 250v/5A, the switching regulator of the SMPS primary section is faulty, so the fuse blows of continously
Dec 22, 2007 | RCA DRC200N
212 people viewed this question
 Grubhead
Grubhead
