Question about E-Machines eMachines T3830 PC Desktop
T3830 not turning on - E-Machines eMachines T3830 PC Desktop
  • E-Machines Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in. Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. Another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit. If you can get your computer stable enough scroll to bottom toolbar bottom of screen right click select task manager applications you will see whats running if you see anything you dont need running select end now also under processes see what is ticking over again if you see something you don't need to be running end now or you might uninstall that program and some unnecessary programs not having enough computer ram can cause memory dumps If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always for a guarantee on any ram modules when purchasing them or buy working pairs if possible. You might have a virus or malware. Download at least one of these of course it will depend on your operating system. http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials Hope this helps.
Posted on Dec 08, 2012
  • 1,511 Answers
Hi and welcome to fixya
firstly check your power cable of the CPU and then if this isn't works then put the RAM from the CPU and then reinsert it if still isnt work then there should b a hardware problem
I have the problem of ethernet controller and i can not have access to internet. please help me
http://download.driverguide.com/driver/T3830/Emachines/d1753694.html
this is a link to a driver site you should sing up in order to get acces to site
this works just for win xp
if you have a different like windows vista ot windows 7 you need to get a diferent driver if it exist.
if you have a further question let me know sincerely :inggalaxia dont forget to comment and give a vote
Jul 11, 2011 | E-Machines eMachines T3830 PC Desktop
I have a emachine T3830, that I turned off while I was away. When I came back home it will not turn on. What could be wrong?
check your outlet & make sure it's getting power
if you have your pc hooked up to a power strip make sure the power strip is still working
if it's not plugged into a power strip,, make sure all the cord in the back of the tower are securely
plugged in
let me know what what happens
Nov 18, 2010 | Computers & Internet
When I try to push the power button it will not turn on.
you might find it little Funny but my first suggestion is that you should slap your CPU gently then with little force. seems like your ram has got dust thats y and plz tell me one thing does it beep twice.
Jun 15, 2010 | E-Machines eMachines T3830 PC Desktop
Problems putting which wire where
mouse and keyboard are color (purple and green) coded monitor is serial port only fits on one place and screws on! Power plug is at top has three slots in cord! It hard to plug things in wrong! plug um all in and turn it on!!
Oct 22, 2009 | E-Machines eMachines T3830 PC Desktop
HOW DO I TURN ON MY BUILT IN WEBCAM
if its on the screen then look at the manual if you dont have it then look for it on google
Sep 23, 2009 | E-Machines eMachines T3830 PC Desktop
Disco de programacion de t 3830
contact emachines.com go to support give model number and serial number pay $25 USD They will send you one.
Jul 21, 2009 | E-Machines eMachines T3830 PC Desktop
Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Apr 09, 2009 | E-Machines eMachines T3830 PC Desktop
EMachines T3830 PC Desktop - HOW TO INSTALL A VEDIO CARD
There are a couple of things it could be. From simply checking the cable on both ends (computer to monitor) to see if they are loose. It could also be the card is damaged. I would check it with a second monitor to be sure.
Oct 13, 2008 | E-Machines eMachines T3830 PC Desktop
E-Machines eMachines T3830 PC Desktop Logo
29 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
