Question about GE 3.5 Cu. Ft. King-Size Capacity Washer with Stainless Steel Basket WTRE6260FGG
GE wwa8172HDMWH clothe gets stuck
When I wash my clothe gets stuck and tangled. How can I fix this?
I just bought a defy top loader dtl 151 and it keeps tangling the clothes
Here are a few suggestions.
Sometimes too much water ( or not enough clothes) will result in tangled clothes.
Sometimes the types of clothes will tangle more easily than others.
( Thin cotton tee shirts or long cotton dresses might tangle easily. )
I might recommend you mix in some heavier and thicker items to help, such as towels or blue-jeans and see if that fixes the problem.
God bless your efforts.
Aug 22, 2016 | Washing Machines
Why does the agitator keep getting stuck and will only go one way
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
Mar 26, 2015 | Washing Machines
Hi my washing machine is tangling up all the washing around the agitator then going out of balance, stops spinning, lights start flashing and beeping? Please help me...
Make sure the agitator is down as far as it can go on the shaft. If it has worked itself partially off the shaft it can cause a gap that will cause your clothes to tangle around the agitator.
Dec 09, 2014 | Washing Machines
My washer tangles up my clothes. I swear someone goes downstairs and ties the clothes up. They are always a tangled mess thats hard to pull apart when they are wet! Help!!!
Make sure you are not over filling the washer, when my mother in-law does the laundry, it ends in a tangled mess. However when I wash them, no problem I shake the clothes out before I put them in and I try not to overload the washer.
Feb 27, 2011 | Hotpoint VBSR3100GWW Top Load Washer
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
Simpson eziset 800 clothes tangle when washing
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad!
If this is the problem it could be the switching module or capacitor that needs replacing.
Oct 25, 2009 | Washing Machines
Agitator Dogs tangle clothes
No - The clothes will not agitate properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Neptune washer tangles all cloths
the washer has a balance ring that hold water that is ok. as of the tangleing you may have a low water fill
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE 3.5 Cu. Ft. King-Size Capacity Washer with Stainless Steel Basket WTRE6260FGG Logo
62 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
