My hp dv2000, has crashed due to amother board problem. It's said, because it has a nvidia graphic card, it's not possible to repair!! Only solution, to replace mother board, where I'll get a one month warranty!! but, I would like to have a better solution. I would like to know, if I can replace a mother board without nvidia n run it longer!??
  • 46 Answers
If you still have 1 month warranty its best to get it sent off now to be fixed otherwise it may be rather expensive to fix yourself the graphic card is onboard the motherboard so its all in one
Posted on Dec 14, 2012
pincer
  • 377 Answers
SOURCE: DEAD MOTHER BOARD
in here..?
Posted on Jun 27, 2008
leecom72
  • 4806 Answers
SOURCE: can I replace my mother board with one that has
I'm afraid not, laptop motherboards are unique to the models and really cannot be swapped out to different machine, not only that they are just as expensive as purchasing another laptop with a decent graphics card installed.
I recommend that you follow the advice given here and purchase another machine for gaming purposes, if go out and buy another motherboard you may find it won't fit in the case and you will have wasted your money.
Alienware make excellent gaming laptops and are designed with graphics punishment in mind, these are expensive laptops but are well worth the money.
Regards.
Posted on Jul 10, 2009
MNfisherman
  • 11896 Answers
SOURCE: my Laptop DV6000EU in Aug 2007. Warrenty on Mother board
It would be under warranty for only 1 year. I would check to see if is loose or faulty memory chip. Try removing one and turning it on. Or try remove battery pack, press and hold power button for 5 seconds, put battery pack in and try turning on.
Posted on Nov 12, 2009
  • 44 Answers
SOURCE: nvidia 8600m graphics card repairable
If it is a graphic card and not and integrated, then it is replaceable. Not sure about being repairable though.
Posted on Dec 19, 2009
  • 17 Answers
SOURCE: Is it possible to replace Nvidia 8400M GS
defenetly the chip of nvidia located on your motherboard will change. please specify motherboard mac and revolution for the same
Posted on Dec 22, 2009
HP Pavilion Entertainment PC Laptop DV2000
when you say some times it keeps going does this mean the unit turns off ??,,,,this model has the gpu problem,,,dry solder joint of the graphics card, of which you can have the board repaired or replace the board
Oct 06, 2012 | HP Pavilion Computers & Internet
UPGRADE of CPU and graphics card in HP Pavillion 9000?
The HP Pavilion dv97072ea Notebook PC?
http://h10025.www1.hp.com/ewfrf/wc/product?product=3308945&lc=en&cc=us&dlc=en&lang=en&cc=us
Nope.
Doesn't use the MXM technology, with using a separate graphics ->adapter card.
The graphics chipset (GPU) is soldered directly to the motherboard. (GPU on a small circuit board, that is)
It's Integrated Graphics,
http://www.ascendtech.us/hp-434659-001-dv9000-laptop-motherboard_i_mbhp434659001lm.aspx
Scroll the page down to the larger photos.
The Nvidia GeForce GO 7600 mobile graphics chipset, is the darker OD green circuit board. (Generally speaking)
In the views you are looking at the TOP of the motherboard.
You see the white rectangular Processor socket, with the square hole in the middle.
Next to it is a green square circuit board, and next to that is the darker, Olive Drab green square circuit board, that is the Nvidia GeForce GO 7600 graphics chipset.
{Circuit board and GPU, is referred to now as the graphics chipset.
That is why I stated - Generally speaking, above }
[GPU,
http://en.wikipedia.org/wiki/GPU ]
You can see the Nvidia GeForce GO7600T chipset, and circuit board, more clearly here,
http://www.ebay.com/itm/100-new-nVIDIA-GeForce-GF-GO7600T-N-B1-GPU-BGA-IC-Chipset-with-Balls-/190698089722?pt=LH_DefaultDomain_0&hash=item2c667decfa
It's mounted to the motherboard with a BGA surface mount.
Ball Grid Array.
To explain the Ball Grid Array surface mount, simply;
In the photo of the chipset in the Ebay link above, you are looking at a green square circuit board, with an Nvidia 7600 GO, mobile graphics chipset, in the middle. You are looking at a TOP view.
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_Go_7_.28Go_7xxx.29_series
The GPU ->Nvidia GeForce GO 7600, is mounted to the green circuit board.
The bottom of the green circuit board has Solder Balls.
The Solder Balls take the place of Contact Pins.
(Contact pins, such as on the bottom of an Intel Pentium 4 processor, that uses a Socket 478 processor socket)
On the motherboard are matching Copper Pads.
(The copper pads are coated with a gold plating)
The Nvidia graphics chipset is set down on the motherboard, with the Solder Balls lining up on the matching Copper Pads.
Heat is then applied at a specific temperature, and length of time.
This action makes the solder balls melt, and solders the Nvidia GeForce GO 7600 to the copper pads.
(Which in turn solders it to the motherboard)
This demonstration of a BGA Rework Station, shows you more about the above technique,
http://www.ersa.com/art-ir-pl-650-346-1472.html
Go down towards the bottom of the page, and click on the Red -
Take a few minutes to view the IR 650 demo video. (5 minutes)
Just for edification;
If it indeed did use the MXM technology, and a graphics adapter card for a laptop, that is based on the Nvidia GeForce GO7600 GPU, it would look like this, and plug into an interface, (Connector) on the motherboard,
http://www.ebay.com/itm/nVIDIA-GeForce-Go7600-Go7600-N-A2-G73M-DD2-256MB-MXM-II-VGA-Card-35G1P5310-10-/330758557353?pt=PCC_Video_TV_Cards&hash=item4d02bf0ea9
(There is also a model with 128MB of graphics memory, besides the 256MB model shown above)
More in a Comment. Don't give up on increasing graphics 'power', just yet............................
Jul 07, 2012 | Computers & Internet
HP notebook screen
If you've tried a working lcd screen and you still get no display then your video card is bad. The hp dv2000 has the Nvidia Graphics Card (video card) that was a manufacturing defect and was put in many different manufacturer's models other than hp. It was a total nightmare and well documented all over the internet.
Your graphics card will have to be reflowed. You can do it yourself by taking the motherboard out then wrapping it in Aluninum foil leaving the Nvidia graphics chip exposed. Take a hair dryer (blow dryer) and with a sweeping and circular motion for about 1 minute go all over and around the graphics card applying HOT heat. Take a pencil with an erser on it and use the eraser end to push in the middle and all around the edges of the video card to reseat is securely. Repeat this for another time or two then remove the aluminum foil and let the board cool off. Insert it back and most likely your problem will be solved. I've done it many times and I use a really hot Shrink Wrap gun. It works 99% of the time.
May 24, 2012 | Computers & Internet
My Nvidia GeForce FX 5500 / 256MB DDR / AGP 8x / DVI / VGA / TV-Out/ Video Card Graphic Card Crashes when I try playing games?
The graphic card usually crashes due to over heating. Keep the gpu cool. you may use a pedestal fan as well.
Mar 25, 2012 | Nvidia GeForce FX 5500 / 256MB DDR / AGP...
Laptop is having trouble booting up.
HP Limited Warranty Service Enhancement - HP Customer Care (United ... If you own an HP Pavilion dv2000, HP Pavilion dv6000, HP Pavilion dv9000 or Compaq .... Willthere be a future BIOS release that does not make my notebook fan remain ... Black Screen Error Messages that may Occur During Startup or Boot ...
h10025.www1.hp.com/ewfrf/wc/document?docname...lc=en...
Apr 05, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
I have a hp iq780 touchsmart pc.recently nvidia 7600 graphic card got crashed & its display got corrupted so, i switched to the motherboard graphic card nvidia 6100.wanted help in recovering 7600...
if the hw is working fine then you can go to the device manager and uninstall the driver ... and then go to the nvidia website and install the driver sw for it
Mar 17, 2010 | HP TouchSmart IQ770 PC Desktop
My Hp dv2000 boots up after 4th attempt but no colour on screen ? I had it checked the tec man says the graphics card gone on mother board ? is this possible caus its about two years + Old Help !
This is a common problem with the hp dv2000. Check out www.msbin.com Their DIY guide might be able to fix your issue with the graphic card. The problem is caused by the GPU on the systemboard.
Sep 24, 2009 | Dell Latitude D600 Notebook
Driver Problem
Jan 28, 2009 | HP Pavilion dv2000t Notebook
My dv2000 boots but screen is split into like 8 parts (each part showing same thing) there are some wavy lines..sometimes its ok ...i try to load windows vista recovery (from partition) - it crashes on...
I have the same problem that my screen splits into 6 but occasionally screen comes normally. I gave to HP service center and they told me to change my mother board. I was worrying about the cost of Mother Board bcoz it costs 1/3 of my purchased rate and also my warranty was expired just 2 months before.
So, I tried some way to fix this temporarily, while screen comes normally, I went to Safe Mode, it works fine. So, I got an idea, it works in less hardware access, I think, how it works when removing NVIDIA display driver. So, I removed it. Now, it works fine but there is a difference in display but that doesnt matter while comparing previous.
I'm still searching permanent solution. I'm planning to change the Hardware of NVIDIA card. Lets see,
Jan 19, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Computers & Internet Logo
David Payne
David Payne
