Question about ASUS New 14" x401u laptop pc with 4gb ddr3 ram 320gb hd amd e1
How to open casing notebook asus x401u - ASUS New 14" x401u laptop pc with 4gb ddr3 ram 320gb hd amd e1
Why is safe mode not working
Please mention a bit of more information, what is exactly happening? Is it restarting during the drivers loading or something else. and why are you trying to load it in safe mode?
Jul 17, 2014 | ASUS New 14" x401u laptop pc with 4gb ddr3...
Touchpad stops working after standby
check function FN + F9
Don't just take my word for it
see
http://support.asus.com/Troubleshooting/detail.aspx?SLanguage=en&m=X401U&p=3&s=415&os=&hashedid=gt7tGwyBZJKmXv4z&no=1018
Jan 26, 2014 | ASUS Computers & Internet
My Win 8 Laptop Can't Find My Wireless Network upon Restart
Dear frnd,
you need to check first does your laptop has wireless driver?. if not then you have to install driver first then it will work. if you brought new laptop then you have got an driver cd with it. install the driver from the cd or if you didn't got the cd then go through asus website and search the wireless driver with your laptop model no. hope it'll work..
Jan 15, 2014 | ASUS New 14" x401u laptop pc with 4gb ddr3...
Need help wif an asus x401U ... Brought it on eBay ... Turned it on and is asking for a password ? Tried contacting the seller but will not get back to me ... Plz help!!! Tash
disconnect all power cables and remove the BIOS battery from the system board for at least 2 minutes. this should perform a complete BIOS reset.
Oct 09, 2013 | Computers & Internet
MY asus x401u dosent get past the reboot menu what can i do
You need to re-install Windows..I'll suggest getting Windows 8 as its quite better than Windows 7..better office, better Outlook 2014 and better speed.. :)
Jul 11, 2013 | ASUS X401a 14.1-Inch Laptop Black Intel...
Does anyone know where the bluetooth card is located inside the case i have an Asus M51A and purchased a bluetooth card and cable for it but not exactly sure where to look to plug it in id like to take as...
If you use a USB bluetooth, :http://www.amazon.com/s/ref=pd_sl_6dpb1p23dn_b?rh=i%3Aaps%2Ck%3Aasus+bluetooth+adapter&keywords=asus+bluetooth+adapter&ie=UTF8&psrk=asus+m51a+bluetooth+card+hardware+replacement, you would not have to open the laptop. Are you comfortable with opening a laptop? Do you have the tools and expertise? Take a look at the ASUS manuals: http://www.asus.com/Notebooks/Multimedia_Entertainment/M51A/#download
Nov 17, 2012 | ASUS M51A-A1 PC Notebook
I WISH EVERY THING RUN SMOOTH?
My friend, I think it is time for a change.
I may suggest the newest ASUS X401U (~250euro) or his more powerfull brother ASUS X501J (~300-350euro). Even so, If your budget alows it, you might go for a most powerful solution like - K56CM which is around 800euro, but packs a real punch.
I recommend the first two options, for running it smooth and everything will play nice :)
please check their website www.asus.com which will provide with lots of info on the matter.
Oct 22, 2012 | IBM ThinkPad i Series 1400 Notebook
Trouble seperating top cover from base/mobo / asus f3s notebook
Have you removed the keyboard, sometimes there is a screw under the keyboard that holds the top and bottom of the case together.
Most laptops have clips/indents that clips top and bottom half of the case together. Start on one side, preferrably at an opening where the CD/DVD drive is located and gently apply pressure to separate the case along that edge. Once you free a catch/clip start working along that edge and continuing around to each side of the case.
Mar 26, 2009 | ASUS F3SC-B1 Notebook
ASUS L3500 Keyboard
you remove that using screw driver and be careful to remove the casing be sure the lack is open from the case...or you just get a manual and follow the step to open the casing.....
Dec 10, 2007 | ASUS L3 L3562 Notebook
ASUS New 14" x401u laptop pc with 4gb ddr3 ram 320gb hd amd e1 Logo
460 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
