Question about Alps Office Equipment & Supplies
Alps md5000 printer driver for pc with windows 7
    New Friend:
  • 83 Answers
Sorry, there are no Windows 7 Drivers. There are a couple of work arounds. I use an older laptop with Windows XP. The XP drivers are easy to find on line. There is another way, but I have not tried it. It's using XP compatibility mode in Win 7.
Posted on Dec 10, 2012
SOURCE:
  • 83 Answers
SOURCE: MD 1000 Thermal Printer: I need a driver for ALPS MD1000 printer that will ...
Go to the ALPS Yahoo Group. They have an extensive file section with drivers. Windows will use the default plug and play driver for the printer. The MS version is very limited. You should rename the MS driver to something else like "MS Alps Driver" and then install the ALPS driver you find at the Yahoo Group. These will give you full functionality.
good luck
Posted on Jun 04, 2010
fcollingwood
  • 58 Answers
SOURCE: Looking for an Alps MD5000 driver for Mac OSX
There are no OS X drivers for the 5000.
If your version of OS X is old enough, you can run the )S 9 driver under classic.
Posted on Jul 19, 2009
  • 83 Answers
SOURCE: I'm looking for a vista or windows 7 driver
Sorry, there are no Windows 7 Drivers. There are a couple of work arounds. I use an old dedicated laptop with Windows 98 to print to the ALPS printer. There is another way that I have not tried - opening an XP console in Windows 7.
Posted on Apr 27, 2010
  • 83 Answers
SOURCE: i have an a Alps md5000 ,iwant to work like Powis foilfast 21
The MD-5000 will print foils.
Posted on Jul 14, 2010
virtualhost
  • 2185 Answers
SOURCE: I am looking for Alps
Currently, there are no available driver for Alps MD 1300 for Windows 7 as this has not been released at all. However, you can find the download here for other version like xp or windows 2000.
http://www.opendrivers.com/driver/213050/alps-printer-md-1300-driver-2.24-win2000-xp-free-download.html
Posted on Sep 16, 2010
Alps 1300 printer drivers for win 7
There are no Windows 7 drivers for the ALPS printers. Since you are running W7 Pro, using the virtual XP mode will work. To get full functionality of the drivers, you need to have a motherboard with a built-in parallel port.
Jan 07, 2012 | Alps MD 1300 Thermal Printer
Alps MD 5000
1. delete any MD5000 printer entries. *(I had no other printer entries defined)*
2. Use ADD/REMOVE programs to remove the driver.
3. Disconnect printer USB cable (one you bought on EBAY) My laptop has no Parallel port.
4. Reinstall Driver (I am using 2.2.4) specifying not to make it the default printer. For me the 2.2.4 install worked fine.
5. use the add a printer function to manually add the MD5000P. I pointed the install wizard to the 2.2.4 file created by the installation of the driver when it asked if I had a disk. for my computer that was:
C:\Documents and Settings\AMD64\My Documents\My Received Files\MDP224XP
5. after the printer definition was successful , I followed the steps from a
previous message in the ALPS group listed below listed below:
RIGHT CLICK MD5000P ICON, and open properties menu for said printer (this is the one you created manually)
click PORT TAB:
pick a USB port ( virtual printer port) from list *(the install set it to a
port of MD_LPT1 I selected USB001)*
DISABLE bi-directional support RADIO BUTTON,
click ADVANCED TAB:
click PRINT DIRECTLY TO PRINTER radio button,
OPEN PRINT PROCESSOR BUTTON on bottom of page,
from menu select ALMD224S (for print processor)
and DATA TYPE select RAW(FF AUTO).
I plugged the printer in a USB slot and printed test page and a color
photograph.
After this all worked I reset the USB port definition to reselect the bi-directional function. So I do run with the bi-directional mode
Note that Win XP itself will auto create a printer definition using a Microsoft driver "Alps MD-5000P (MS)" if you use this printer to print you will not get any of the ALPS functions.
But this seems to have worked for me.
I hope this helps you. I have only worked with an Alps MD5000 so I have not done this with any other model but the steps I think the steps could still apply because of windows requirements. I have not tried to install the driver on Vista so I do not know if it will work but it might.
Hope this helps.
If any of this is a problem you can contact me and hopefully we can work it out on the phone or chat or whatever
Good Luck
Jan 27, 2008 | Alps MD 5000 Thermal Printer
Can our ALPS MD 1000 printer work with Windows 7? We used it when old computer had Windows XP on it, but that crashed and bought HP with Windows 7 now... we need Alps to make waterslides for custom rod...
There are NO Windows 7 drivers for the ALPS MD printer. I've read that you can run an XP virtual mode on Win7 that allows you to use the printer. If you are comfortable tweaking the OS, it's a workable option. I picked-up an old (and cheap) laptop on Craigslist and printed my decals from there.
Sep 15, 2011 | Alps MD 1000 Thermal Printer
I have an alps MD400 and am running xp pro with drivers for xp and can't get the thing to print and need a trouble shooter
There are WinXP drivers for the MD-4000. You can find them in the files section in the Yahoo ALPS Group. There are some conflicts with the Windows XP (Service Pack 3) and the ALPS printers. It is best to connect to a computer running SP2 and has a parallel port. The ALPS group also has the Twain for the Scanner. The MD-4000 does require a carrier to scan things.
Dec 17, 2010 | Alps MD 5000 Thermal Printer
I'm looking for a vista or windows 7 driver for my Alps MD-1000
There isn't any Vista and Windows 7 drivers for this printer. The manufacturer still hasn't produced any. This is really sad because I have the same printer and I have to stick with XP just to be able to use it.
- HotRatchet
Dec 15, 2009 | Alps MD 1000 Thermal Printer
May 24, 2009 | Alps MD 5000 Thermal Printer
MD5000 to MACBOOK PRO problem
MAC is NOT my forte... however, I do know that ALPS offered THIS a few years after the MD5000 came out:
USB Interface Kit for the iMac OS V8.01 and Windows ($99)
You might find it on ebay etc. and be able to use it (no support with this printer on OS X!).
Apr 08, 2009 | Alps MD 5000 Thermal Printer
NEED TO HAVE INSTALL SOFTWARE FOR wINDOWS VISTA
Join the Alps mailing list at YahooGroups. The drivers are in the files section.
http://tech.groups.yahoo.com/group/Alps/
Apr 08, 2008 | Alps MD 1000 Thermal Printer
Installation disc for win 98 Alps md5000 is currupt and wont install, can you help me
Join the alps and alpsdecal groups at http://www.groups.yahoo.com. The drive is in the files section of one of the groups.
Feb 15, 2008 | Alps MD 5000 Thermal Printer
1,275 people viewed this question
Top Alps Office Equipment & Supplies Experts
Clive
Clive
defcon000001
Level 1 Expert
Jesse Walters
Jesse Walters
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
