Question about Cameras
Inserted Battery Wrong, Now I Can't Remove It.. Help?
I need help, I inserted my battery wrong and can't get it out ,someone help!! (Panasonic Lumix DMC-FS14)
  • Alma Dyrmishi Dec 08, 2012
    I've tried so much times man with so many things what actually works without having to buy a new camera? heellpp
  • Alma Dyrmishi Dec 10, 2012
    Ok, so basically, I have the camera Panasonic Lumix DMC-FS14, and accidently , I put the battery in the wrong way and now I cant get it out, I have family photos that I have no where else :((.....Please someone help (without buying ANYTHNG).. any help??? :( Thanks.
3 Suggested Answers
  • 1705 Answers
SOURCE: windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
Posted on May 02, 2010
SOURCE: Panasonic Lumix DMC FZ30 - LCD white screen.
Firstly, use the following information at your own risk, I am simply providing my own findings for informational purposes. It may or may not be the solution to your problem. If you want a professional opinion, go to a camera repair specialist...
I have had the exact same problem. The screen on my Panasonic DMC-FZ30 started to go white with lines through it in certain positions, and then in all positions. Finally it went black.
I took my camera apart to try and find the source of the issue with my screen (by the way if you want to take your dmc-fz30 apart, there is a fantastic service manual download for free at: http://www.nemodus.info/fz30/docs/DMC-FZ30_DSC0508016CE_v1.pdf or if that does not work try http://elektrotanya.com/panasonic_dmc-fz30.pdf/download.html ).
I believe the issue stems from the contacts of the rotating screen. I would hazard a guess that somewhere along the flexi-cable there is some wear which has caused this to occur...
I have not yet solved the problem, however I do have two potential solutions.
1. I found a site where you can buy a replacement flexi-cable for the camera. The site is (http://g-plushk.com/product_info.php?cPath=53_56&products_id=653). The cable costs approx $12 (not sure which currency, it doesn't say).
The issue with this solution, after taking apart my camera, I could find no way to remove the cable completely from the swivel joint at the base of the screen. So you would probably have to buy the part and take it to a professional. (probably check first whether it is even possible to replace, I assume it is, as they sell the part...just my guess).
2. The second solution (easier in my opinion, but a bit more expensive I'm guessing). You can buy a replacement screen for the camera. Contact Panasonic for your closest spare parts distributor. I do not know the price for a replacement screen, but I would estimate that it is between $30 to $50 AUD. I would then install the part myself as it is fairly easy if you follow the service manual. However if you would prefer not to do it yourself, I would seek the help of a camera specialist to replace it...
By the way, just to put a repair in perspective. You can PROBABLY (not definitely) buy a second hand 'Panasonic Lumix DMC-FZ30' for somewhere between $80 to $120 AUD...
Hope that helps
Posted on May 04, 2011
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
New home Janome 2039 sewing machine
if these suggestions don't help then the machine needs to be
checked for a timing problem
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Mar 29, 2013 | Janome Harmony 2039 Mechanical Sewing...
I am getting no memory card inserted
Remove your battery
insert your memory card
insert your battery
Power On.
if still no memory card inserted
Replace your memorycard
something wrong with your memory reader (parts of cellphone)
Jan 19, 2013 | Nokia N73 Cellular Phone
What's wrong with the machine when the thread is skipping on top and bottom.
hi, it could be several things
damaged needle---try new needle
needle is not correctly inserted into machine----flat side of the needle goes to the back of the machine
wrong size needle for the fabric--choose a needle to suit thread & fabric
the wrong foot is attached--select correct foot
if you check all these things & they don't help then it's possible the machine is out of time
Sep 08, 2011 | Simplicity Creative Spirti PLus SA2200...
Inserted battery the wrong way
it can be removed but be very careful
Sep 05, 2008 | Olympus Stylus 850SW Digital Camera
Fugi Z10
buy a new battery matee, i did the same thing, i bought a replacement battery on ebay, works a treat and im guessing half the rice of what you would buy in stores. good luck!
Jul 19, 2008 | Fuji FinePix Z10fd Digital Camera
Stylus 850
Hey jlnatc,
According to the manufacturer if the battery is inserted the wrong way you should be unable to remove the battery, and you should not use force in trying to remove it. You should bring it to an authorized service center and they should be able to remove the battery. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they could send it out to have it serviced, or you could contact the manufacturer and they usually have a list of authorized service centers. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 24, 2008 | Cameras
Battery
A tool known as "duck-billed" pliers works for the stuck in the wrong way battery syndrome. They are flat-nosed, pliers of the "needle-nose" variety.
Jan 01, 2008 | Fuji FinePix Z1 Digital Camera
Battery inserted wrongly and now cannot remove
I did the same thing. Don't send it back. I used my fingernail (it hurt like hell), and then used a blunt end of a spoon. It doesn't break very easy, jsut don't dig in, cut it, or put force on that black plastic part.
Dec 25, 2007 | Cameras
The battery should still be removeable - have you tried to move it or turn camera so the the open chamber is facing down and tapping the camera
Dec 25, 2007 | Fuji FinePix F401 Digital Camera
Cameras Logo
42 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
