Question about Dyson DC11 All Floors Bagless Canister Cyclonic Vacuum
My bristles wont spin - Dyson DC11 All Floors Bagless Canister Cyclonic Vacuum
    Novelist:
  • 171 Answers
Hi Maggie,
Alec from VacuumSpot here. There are 3 reasons why the brushes might stop.
The first and easiest is to check if the turbo head is set to carpet - there is a selector on the side that also acts as a bit of a filter. It's an obvious one but sometimes overlooked.
The second and cause is also easy to fix is if your filters are worn or dirty. You wouldn't notice a marginal drop in suction from day to day but over a year the filters do reduce in performance. Once they wear (I know they are meant to be lifetime but they are not) they just need to be replaced. For the best performance just buy new DC11 filters every couple of years they are cheap and it's worth it.
The other thing can be that the roller brush is in need of a good clean. Remove the base plate and pull the rollers out to either side, you will find they simply slip off the shaft with a bit of effort. Clean inside the brushes and also the shaft. Normally you will find a bunch of hair and fluff inside which can slow the roller down.
If you clean this and also make sure you have clean filters and the roller still doesn't spin unfortunately the bearings in the head are wearing and the head needs to be replaced as Dyson hides the bearings in a sealed casing forcing you to replace rather than repair.
I hope this helps you out.
Regards
Alec
Posted on Dec 10, 2012
Already replaced filters. Suction is fine. Only have short nap rugs. Is not picking up hair, thread small things on the carpets. I have cleaned the bristles on bottom as well.
Turn the vacuum over with the bristles up. Turn on the vacuum and see if the bristles are turning. If not, then replace the belt that makes the bristles spin.
Mar 05, 2016 | Vacuums
Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
I have a Kenmore "Intuition"
I had a different vacuum that did this. I took all manner of things apart looking for blockages and the like .I found that by having the vacuum handle in the full upright position shuts off the suction to this area and doesn't power the brush BY DESIGN. I think this is to get more suction to the hose.
Dec 18, 2017 | Kenmore 25512/ 25513 Progressive Canister...
The bristles will not spin.
See if the belt (that drives the bristles) if is loose or need replacement.The belts are located either on the left or right side of the bristle brush(you can locate it by putting the vacuum upright and see under the brushes). If it is loose or broken replace it(walmart has replacements for it or any hardware store)just bring the belt for the replacement number written on the belt,or know the brand and model number.
Nov 19, 2010 | Bissell 3522 PowerForce Bagged Upright...
Belt not turning, smells hot, I cleaned brushes and everything.
Check to see that the belt has not slipped off of the bristle bar. If it smells hot that typically comes from the smell the belt makes if it is slipping. It will slip if it is not able to turn the bristle bar. Disassemble the bristle bar from the chassis and check the ends of it too see if they spin freely. It's typical that the ends get tied up with carpet threads and hair. Remove that mess, and then use some lubricant like silicone or Crisco cooking oil on the dowel of each end that is holding the bracket you had to unsnap from the chassis to remove the bristle bar.
Nov 02, 2010 | Dirt Devil M088920 Upright Vacuum
Worn Dyson beater bar bristles
Worn bristles are a fact of life for all vacuums with a brush roll. Where I work, we're changing them all the time! I don't think anyone has yet invented perpetual bristles. Sorry, but you'll have to fit a new one.
Feb 21, 2010 | Vacuums
Brushbar wont spin
If still under warranty, take advantage. The brush roller may have bound-up bearings on the ends--usually string, thread, and hair are the problem. Check the drive belt for wear or damage. Hope this helps!
Dec 26, 2009 | Dyson DC25 All Floors Bagless Upright...
DCo7 too much suction hard to push
This suggests that the bristles on your brush roller are worn out.  When the bristles are a good working length, rotation of the roller actually helps to pull the machine over the carpet. When the bristles wear down this effect is lost.
May 20, 2009 | Dyson DC07 All Floors Bagless Upright...
The vacuum turns on, but the thing with the bristles doesn't spin. Help?
no it can't be bypassed the motor is dc.the circuit board converts it from ac to dc
Apr 12, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Dyson DC11 All Floors Bagless Canister Cyclonic Vacuum Logo
76 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
