Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Door not clicking shut
I have a hotpoint fdw60 dishwasher and the door wont click tight it has been working in the same location for last 4 years.
  • 1 more comment
  • Anonymous Jan 13, 2009
    My FDW60 has just developed this prob too! Nothing has happened to the appliance, just the door problem
  • Anonymous Jan 20, 2009
    Could you tell me where you got the part from please?
    Cheers
    Mel
  • rocketron10 Feb 06, 2009
    Same really the door doesnt click shut,the door doesnt go in flush with the rest of the machine,when we try to close it,the rest of the machine is fine but for obvious reasons we cant use it ,can you tell me where i could purchase the part ,for the FDW60.
    Thanks
    Ron Taylor.
I had the same problem. There is a spring on the catch mechanism that breaks. Replace this and it fiexes the fault.
Posted on Jan 13, 2009
Hotpoint FDW60 DishwasherTablet does not dissolve
our HOTPOINT FDW60 is not working right?
the tablet is not disolving inside right how will i fix it?
Feb 07, 2013 | Hotpoint 24 in. FDW60 Free-standing...
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
I have a hotpoint aquarius dishwasher. although the door shuts it will not lock. Sometimes the door will almost shut but the lock seems to jam. Thanks Jim
Possible that this is a mechanical fault. So you might have to remove and clean the lock with a de-greasing spray and close the door few times as you oil it. this might solve the issue.
Please find help on the link below for tips to repair
Dishwasher
Dec 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher issues
it can be the 10A fuse located in the back of the machine. but.... storage is kind of a problem with determining what is wrong with it.
Mouse can have chewed the wires, moisture can have rusted or corroded some components.
Check the internal fuse first and please check all wiring fo damage.
May 04, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Door won't shut Hotpoint FDW60
It maybe installed to high and if you lower the legs to lower the D/W you should be able to see that it will fix your problem.
Mar 18, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW60 heater replacement
The heater is the black element at the bottom of the tub. you can see it when you open the door, there are 2 wires attached to it under the dishwasher along with 2 nuts and some rubber washers to keep it from leaking, It is a simple job to replace. Remove the wires undo the the nuts that hold it to the tub, and there may be some brackets inside the dishwasher that secure it in place. remove the element and replace it. Install in the reverse order you took it apart.
Feb 22, 2008 | Dishwashers
Problem with hotpoint aquarius fdw60 diswasher
My mother has a neighbour who has a new hotpoint dishwasher which caught fire inside (Plastic on door front melted!).
Please contact Hotpoint - if yours is new, check to see if they can replace immediately otherwise its worth booking the engineer to sort £90 - free parts on machines less than 5 years old.
Jan 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
476 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
