Bosch maxx 5 leaking water from underneath
My washer is leaking a lot of water from underneath - any ideas what this could be please?
  • Lisa Dean Dec 08, 2012
    Its definitely not a worn seal around the door - you can actually hear the water pouring into the bottom of the machine during draining cycle - I've had the back and top off but cannot see anything obvious - all pipes appear to be intact. Does anyone know whereabouts the filter on the machine is?
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
Posted on May 12, 2007
  • 1462 Answers
SOURCE: Bosch Washer WFK 2401
leaks could be from anywhere. remove the top and back cover, put on a cycle and try to trace where leak is. sorry if this is not very helpful. water in filter should not smell. this may be due to using liquid detergent which causes a smell like drains if used over a period. put on a boil wash and revert to using powder
Posted on Jun 14, 2007
  • 223 Answers
SOURCE: Bosch nexxt washer is leaking from underneath
All the things that greendude said plus check the seams inside the drum as if these have even slightly parted it could cause the leak you're describing. Good luck.
Posted on Sep 26, 2008
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Water underneath my Sears Kenmore washer. Ive had
It could be splashover depending on what you have in the washer (different load sizes). Sometimes the water just splashes over the sides. But I have seen pumps that leak out their seal intermittently. I would suspect the pump.
Dec 30, 2009 | Kenmore Washing Machines
Washer overflowed, water all over the floor, any
you have a leaking pump and need to replace it.
Sep 14, 2009 | Maytag Performa PAV2200
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
My washer is leaking water from underneath. How can I fix this problem
Are you sure its from underneath as a lot of washers seem to be leaking underneath but its actually a blockage in the soap dispenser. Or the water pressure is too high and splashing out of the dispenser in this case make sure the m/c is level front to back.
Mar 07, 2009 | Roper RAS8244KQ Top Load Washer
Water leak
Replace the water pump. They will leak.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Fisher and Paykel Washer leaking water
hi there,
the leak underneath could be from the pump or the drain hose. some washers have a tub to pump boot that sometimes springs a leak.
for a 4-month-old washer, i would certainly hope you pay nothing. F&P appliances come with at least a 2 year warranty. check your user & care guide for warranty information.
Oct 03, 2008 | Washing Machines
Gld5860l00ss QuietPower2 water leak
did you fix it yet ? check water line fittings underneath if you can pull a bit out washer to watch underneath when running to see where and when in cycle it leaks don't touch any electrical connections safety first LOL. disconnect power wipe dry and then ren it through a quick wash or other cycle and see.
Jul 10, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Help please water leak
HERE is your service manual MAybe that will give you an idea
Jun 18, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
