Question about Hoover VHC391 T-80 Dryer
I have a hoover tumble dryer VHC392T the heating element has blown I can get to the heating element but the wires go into the back of machine & I can't get back or sides off to get to them!! I
Can't replace heating element
4 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: The felt seal on my Hoover HNC175 tumble dryer come off.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, and the felt seal.
You may be able to replace the felt seal at this time, or you may have to buy a new one and install it.
I would also recommend that you do the following while you have gone this far.
Remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Be sure to pay attention to the route of the belt, this will come in handy later when you go to reinstall the belt and drum
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Oct 19, 2009
  • 161 Answers
SOURCE: hoover tumble dryer vhc392T drum not turning.
check the belt to see if it is broken. check the drive motor to see if it is working.
Posted on Jan 10, 2010
Testimonial: "when i can find out how to check the belt i`ll let you know. "
  • 40 Answers
SOURCE: HOOVER AUTO DRY 5050ED KEEPS STOPPING
hi there, I have repaired many of these dryers. It will be a faulty heater element, most likely. They cost about $40. If you get a tradesman to fit it, they will prob charge you about $200 all up. Maybe its better to buy a new dryer for around $300? Good luck.
Lance in brisbane.
Posted on Jun 17, 2012
How do I change the heating element on a hoover vhc 691 b tumble dryer?
Many of the heating elements can be seen and changed by laying the dryer on its back...the element is usually visible from the bottom. I found the part on the link I am incuding for you. Hoover VHC 691B80 Dryer Element 2100W
Dec 15, 2014 | Hoover Dryers
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
My dryer is not heating. Anyone know of an
Jan 01, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Just installed a frigidaire washer/dryer combination. The washer works and the dryer tumbles, but there is no heat for the dryer. Help
Jan 01, 2010 | Frigidaire GLER642A Electric Dryer
Roper model rex5634kq1----won't get hot---already removed &ck'd heating element & attached part (thermostat?)--they're both ok--what else could it be?
Dec 31, 2009 | Dryers
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover TCE660 tumble - no heat
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 12, 2009 | Hoover HDC6 Electric Dryer
Zanussi tc7103w tumble dryer not generating heat
There is a thermostat inside the drum if you open the door and feel up the front you will feel a disc with 2 screws holding it in remove the screws to expose the stat pull the stat out there will be 2 wires attatched to it. If you have a ohm meter check for continuity across the 2 conections or If you connect those 2 wires together and try the machine it should heat if so you will need to replace that stat. If still no heat i would suspect the heater to have failed
Nov 23, 2008 | Zanussi TC7114W Electric Dryer
Dryer runs, tumbles clothes, but does not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Aug 09, 2008 | Maytag SDG4606A Gas Dryer
Broken heater during the dryer cycle
Heating element
Thermal fuse
Wiring
Feb 17, 2008 | Equator EZ 3710 CEE / W Ventless...
Hoover VHC391 T-80 Dryer Logo
134 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
