I have a greenhouse Modine PDP modle heater that I cannot get the Pilot light to light at all . I have checked the LP gas supply to the heater and it is good. I have pushed the reset button as well an
The heater is 12 years old and the thermocoupler appears to be in working condition.
Buffalo12980
  • 625 Answers
SOURCE: Pilot light lit but no heat
the pilot's millivolt generator may be at fault.  if you have a meter that is capable of measuring a very small DC voltage, connect it up to the very end of the thermocouple and the copper cappillary. the thermocouple has a welded bead at the very end inside that generates a small DC voltage. Same principle of a J-K thermocouple. Iron constintan  - two dissimiller metals where joined together produce a voltage when heated.  the thermocouple actuates a millivolt electromagnet inside the valve to keep the valve pellet open.  no voltage there it won't actuate the electromagnet.
Posted on Oct 15, 2007
SOURCE: Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Posted on Dec 06, 2007
SOURCE: Pilot will not light
The Pilot indicator will appear to line up with the arrow on the base, and even push in as though allowing gas to flow, but if it is just 1mm out of alignment, no gas will flow. So the solution is to move the valve in the Pilot mode slightly in one direction or the other to see if/when gas flows.
Posted on Nov 07, 2008
  • 128 Answers
SOURCE: sta-rite lp heater wont start
Its the top. There is a membrane that controls the circuit board....the button pad is bad
Posted on Aug 30, 2009
Testimonial: "Thanks, I agree. After checking power supply all the way through to control board, placing a jumper from pins 9/8 and 9/7 on J6 I get lights on LED's"
SOURCE: kozy world propane wall heater. The pilot light will work
Sounds like you have a common problem with infrared heaters. They are very dust sensitive and they will light and then go out when they are dusty. If you have already tried to blow it out at home you need to take the heater to your propane dealer who will take the heater apart and blow it out correctly. They will then hook it up to their gas line and make sure that the problem is fixed. I hope that you haven't blown up into the bottom of the heater where the gas line is connected. There is a diaphragm up in there and if you blow into it you risk messing it up to where it won't work at all.
Posted on Oct 19, 2009
30000BTU wall heater keeps shutting off LP gas supply.Pilot stays on,when I turn up the thermostat gas comes on, after a short time, gas supply & pilot shut off with a sharp loud noise
It sounds like either the high limit or the spill switch is bad. These are snap disc thermo safety devices. Locate and jump out, one at a time. If unit works when you jump out the limit, replace it. The same goes for the spill switch.
Feb 18, 2017 | Water Heaters
Dayton3e368a pilot lights but burners do not come on. Heat rod was replaced last year. Heater is in a greenhouse
Most heaters has a pilot proving sensor of one type or another, it will be in direct contact with the pilot flame to prove that the pilot is lit and then will allow for the main gas to the burners to open. If the proving device has failed then it needs replaced.
Oct 12, 2011 | Dayton Gas Furnace Heater
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
Haven't run heater for 6mons. Hooked up new tank of LP gas, turned on supply valve, waited 5mins. for line to purge. I could still smell strong gas odor and hear it rushing through the supply line, so I...
HI pilot line open letting full gas through , make up soap and water to make bubbles and brush it around all the joints get someone to turn on tank slowly and you and chek for leaks if it bubbles up if in any not sure get a gas fitter too check it out
Feb 20, 2010 | Desa International RFP30TA 30.000 LP Gas...
Have a vent free lp wall mounted heater.40 lp tank with regulater. pilot light will light but only the tip of pilot light is flame.there is a space between pilot light and tube where lp comes out. does not...
Too much gas pressure. Are you sure that this is a LP heater and not a Natural gas heater? Is the regulator you have rated under 1/2 pound pressure? Try to throttle down the shutoff on the tank to see if pilot gets better. If so, you have a pressure issue. Gas you adjust the pilot gas valve?
Jan 22, 2010 | Procom 10K BTU, Vent Free, 2 Plaque...
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
This is a new whirlpool hot water heater.Pilot lights, burner fires, water heats up to temp. burner and pilot both shut down. Unit has to be started manually each time
LP OR NAT GAS , IF IT IS LP CHECK GAS PRESSURE @ TANK AND MAKE SURE NOT TO HIGH , IF NAT STILL COULD BE THE PROBLEM HAVE THE GAS COMPANY CK PRESSURE
Feb 22, 2009 | General Electric GE SmartWater Household...
Cozy natural gas heater Mod # CLV 335A
get someone to check the gas pressure that is poss problem gas company if nat and the lp supplier can do it
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
