Question about Motorola Talkabout T6550 (7 Channels) 2-Way Radio
Motorola Talkabout 2.5mm headset plug
Normal 0 I cannot find a supplier for the 2.5mm plug on the Motorola Talkabouts. 90 degree plug 13mm long. Anyone have a source of any kind? Bare plug, with cord or without, molded adapter type. Anything but purchasing an eBay item then cutting off the unneeded. I have several projects. Thanks
  • 27 Answers
Posted on Aug 24, 2009
Survelliance headset won't work anymore with motorola t9500
Try leaving the batteries out overnight and see what happens
Aug 13, 2014 | Motorola Talkabout® T9500 Two Way Radio
Motorola talkabout MR350 headset only sends audio and can not recieve
Likely not compatible. One thing to try is to make certain the transmitting unit is turned OFF when you initially plug in the headset. Sometimes if a headset is plugged into a radio when it is already ON, the headset will appear to be in VOX (voice activated) mode and will not allow the user to receive. Also, if this headset has an inline PTT, it may not be compatible with the radio and you would need to use the PTT on the radio.
If this doesn't work, you would need to use the TalkAbout headset designed for the MR350.
Best regards.
Mar 03, 2012 | Motorola MR350R Two Way Radio
Hi I have the T5622 talkabout with a PTT headset. I can transmit OK but I am not receiving anything other than a ''click'' when the other person transmits. I have tested the headset and I am able to recive...
Here a few thoughts which come to mind.
1. You do not mention whether the radios communicate with the headset no on the radio. I will at this point, assume they do.
2. Be certain to have the radio SHUT OFF when plugging in the audio device.
3. Check your VOX settings. It could be your radio is going into VOX mode.
4. Only use the PTT button on the headset. Do not press the PTT on the radio at any time while using the headset.
5. Check that you have CALL TONES shut off.
6. Lastly, if nothing else works, go back to a basic mode, and set both radios where there are no special features turned on. ie turn off CODE, Qt Filter, VOX, Call Tones, etc.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Feb 05, 2010 | Motorola Talkabout T5720 (7 Channels)...
How do I turn off my Motorola Talkabouts?
On the T6500 series turn the volume knob to the click position. This would be OFF. Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
Aug 08, 2009 | Motorola TalkAbout T6530R (14 Channels)...
Can't make the T5420 operate without the beeps!
I have not looked up the T5420 user guide, however, on most Motorola TalkAbouts you hold in the minus (-) button while turning the radio on. Post back if this doesn't work, and we'll find the manual for you.
Nov 17, 2008 | Motorola Talkabout T5420 (14 Channels)...
Communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.de11c4e.jpg
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola Talkabout T6500 will not transmit.
Are you sure the batteries are ok?, try to change the batery, check the radio battery contacts, verify if when you press the ptt, appear an icon on the display that correspond to TX function. Try to use an audio accesory to TX, if all this fail, you should replace it. Good luck
Jan 20, 2007 | Motorola Talkabout T6500 (7 Channels)...
Motorola Talkabout T6550 (7 Channels) 2-Way Radio Logo
653 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
