Question about Makita Drills
How to remove a spindle on a makita drill model 6302
2 Suggested Answers
gaz-dee
  • 62 Answers
SOURCE: need diagram of switch for a 6302 drill
try hear http://www.ereplacementparts.com/makita-6302-drill-parts-c-97_106_147_473.html
Posted on Oct 28, 2009
How to remove the chuck on Makita model HP1640 hammer drill (there isn't any kind of screw inside, only a little hole) help please
Grip a large Allen key in chuck then use a thin spanner wrench on spindle below chuck to loosen.
Dec 09, 2014 | Drills
Sds bit snapped in my makita bhr200 chuck.on taking the drill apart,the chuck is on a gear rod,and wont allow me to push the chuck down
You have to remove the striker bolt from inside the spindle first. to do this remove the internal circlip (not always easy) then you can tap the striker bolt out and then press the broken bit out.
Mar 15, 2013 | Makita Drills
How to remove a keyless chuck from bdf452
If the head of the screw is stripped out to much for a driver to grip and remove it you have two options.
1. Use another drill to drill in the center of the screw with a bit just big enough to remove the head. With the head of the screw off, the chuck can be removed from the spindle. There should be enough of the screw remainin in the spindle that you can grip it with vice grips and remove it.
2. Using a metal cutting wheel on a grinder, you have to cut the end of the chuck off, aiming to cut just under the head of the set screw so you don't damage the spindle. After cutting, let things cool off before trying to remove the rest of the chuck and screw from the spindle.
Aug 11, 2012 | Makita BDF452HW Factory Reconditioned 18V...
Makita 6301LR right angle drill How to change speeds within the right angle assembly ie how to get the damn thing apart! It's off the drill body. Now how to proceed? Also: what are the hi and low...
OK first you need to remove the drill chuck from the spindle, you should have an allen wrench and an open end wrench, remove the chuck retaining screw it is left hand thread, after removing there is a drift pin that is inserted in the hole of the drill chuck and the wrench fits on the hex of the spindle, place the assembly on a block of wood with the pin at about a 30 degree angle so that you have the wrench as a support and would be hitting the pin counter-clockwise to loosen and remove, after removing the chuck screw it onto the OTHER spindle and tighten in the opposite manner, replace the screw and reinstall the RAD onto the drill, this will change the RAD (right angle drive) speed. Let me know if you need more assistance.
Jun 17, 2011 | Makita Drills
Want get some parts manuals
Go to www.makita.ca, search for 6302 and you will get results with manual and part list. Hope it helps. Juraj
Jun 14, 2010 | Makita & 1/2 Inch Drill
Removing chuck from Makita 64C1 drill
secure the short end of an allen wrench in the chuck, making sure it is as tight as possoble. Useing a wood or hard rubber mallet strick the long end of the allen wrench so it turns counter-clockwise. This should loosen the chuck from the spindle enough that you can unscrew it by hand.
Feb 19, 2010 | Makita 6408K 3/8" Variable Speed,...
How do i remove the chuck from the Makita 12v 6227D
There is a left handed screw down at the bottom of the chuck. I believe it is a flathead screw. You need to make sure you are in the lowest gear and turn that screw clockwise. It seems odd, but turning to the right will loosen the chuck screw. Once the chuck screw is removed then you need to remove the chuck from the spindle. Remove the chuck like a regular screw. It has regular threads and should be removed by turning it counterclockwise. Good luck
Sep 07, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
My chuck snapped off, where can i get new chuck and angle bit
OK I assume that by chuck snapped off the spindle is broken and if so there are 2 the low side spindle is part #324170-4 and the high side is 3241699. I believe the gears are a press fit on the spindle. the complete RAD part# is193316-1 and if the chuck only is damaged that number is 193319-5 and from what I can see it is a taper fit on the spindle, I didn't see a chuck retaining screw. If you would like to view the tool go to Makitausa.com and type in your model number and you can get a breakdown and also a list of Makita dealers in your area. Good luck and let me know if you still have any problems
Feb 15, 2009 | Makita DA4000LR Electric Angle Drills
Makita 6408 drill motor. can't see how to replace the chuck.
If you have the 6408 as listed the spindle is threaded and you are correct there is no retaining screw. What you would need to do is find a bent handle allen wrench about the size of the chuck capacity 3/8" and insert the shorter end in the chuck and tighten. put the chuck on a block of wood or workbench and position the long end at about a 30 degree angle in the counter clockwise position and strike it with a hammer, this might take a couple hits. If this is not a 6408 let me know and I will look at the tool for you and see what you got.
Jan 23, 2009 | Makita 6408K 3/8" Variable Speed,...
Drills Logo
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
