Question about HP Officejet 100 Mobile Printer
Installing hp printer
I have tried everything I can not get this printer to install. I am running windows 7 64 bit, It shows in my list of printers it has the green check mark and says ready, But when I try to print it says error, While installing the software it goes all the way until almost the end and says driver not installed successfully, In device manager it says print driver not installed, I am connecting using usb
  • HP Master
  • 2,878 Answers
SOURCE: unable to install conexant cx20549-12 audio driver.
audio driver for hp-530 xp
Posted on Dec 12, 2008
Roswell453
  • 59 Answers
SOURCE: New HP Pavilion, deleted Vista, then Loaded XP, many problems
boy you just went from bad to worse didn't you? O.K. let's see if I can undo some of the thing's you did, and fix some of the ones you didn't try, and your getting this for free, if it works you gotta give me a good rating, na I'm just kidding, I like a Challenge:
here goes do you have the "restore disk?, I'm thinking not, so if you go into your VISTAXP< you named it< start menu and go to
CONTROL PANEL, then look for the Icon that sez system back up and restore, CLICK ON IT AND PICK A DATE WAY BEFORE YOUR DISK THINGY, pick an earlier date and select restore, follow instucts, click yes for e'thing, and you should be good to go, cause even though you "pushed" some XP drivers, you got the warning that there"is a newer version of windows,so install can't cont" message, I hope, then if this all goes well go back through to the device manager AFTER THE DISK RESTORE IS DONE, and check to see if you have any device warnings, if that goes O.K., then you should be good to go, make sure that you back everything up, and hey Promise me you won't do that again,huh, I know Vista, isn't everyones cup of tea, and some say they same about XP, I still want 98, or Mili, Ha,Ha, so anyway I hope I have Helped you get back on track, and you should be able to download any "softpaq"s from the now "merged" compaq/HP, website, by putting in your pav's numbers on the back, (or) bottom, may god bless you and happy 4th, and let me know if you need anything else take care.
Posted on Jul 05, 2009
  • 298 Answers
SOURCE: Device manager says no sound device driver on my
You can download your driver from
http://drivers.myfreewares.com/driverdownload.php
Posted on Aug 28, 2009
sflummox
  • 91 Answers
SOURCE: No sound on my HP Pavillion dv9000 w/ TinyXP (drivers installed)
Some drivers differ by specific model, but the entire dv9000 series probably uses the same sound system. You need to install the second driver (UAA bus) first, then the Conexant driver:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=1842189
If that driver doesn't work, go to the page for the specific model of your laptop. This page shows you how to find the model number:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&dlc=en&cc=us&lang=en&os=228&product=1842189
Posted on Dec 29, 2009
CreativeTECH
  • 1719 Answers
SOURCE: I accidentally uninstalled the sound card on my hp
I have responded to your earlier post. According to the specifications of your PC, it has realtec sound. Click here to download the Sound Drivers. Double Click the downloaded file ( sp26792.exe), which you may have downloaded already. Follow the on-screen instructions to install the drivers.
Let me know if any further clarification is required
Posted on Apr 27, 2011
Can't install printer in windows 7. Not listed in drivers lists
You can download a win 7 driver from here
make sure you download the correct version (i.e. 32 or 64 bit)
Please take the time to rate this answer.
Many Thanks Don.
Sep 05, 2011 | HP DeskJet 3940 InkJet Photo Printer
Tip
Install HP OfficeJet Pro K5400 color printer on Windows 10 64 bit.
I went around in circles for two hours trying diagnostic programs from HP that were supposed to install this printer. Instead they basically just bring up the Windows Add Printer dialog...but the printer was never available from the hundreds of HP printers in the dropdown list.
The solution is to run the Windows update form the Add printer dialog box to get additional printers options. This may take a half hour or more to run, but once it has, it will include the K5400 in the list. Once installed, it works fine with MS Office and Adobe Creative Cloud applications.
on Dec 20, 2015 | Office Equipment & Supplies
I installed hp lajerjet 3050 on windows xp 32 bit...and on another laptop having windows 7 64 bit operating system. when i am trying to share the printer on windows 7 64 bit...it shows drivers not found.
Same Driver will not work for win7 64 bit even if you share the printer it needs the driver for win7 64.
You will have to download the driver for win7 64bit and install in that system.
http://www8.hp.com/in/en/support-drivers.html
Aug 02, 2011 | HP LaserJet 3050 All-In-One Printer
Hp psc 1210 printer driver is not installed sucessfully in window 7 64 bit
When you connected the product to the computer with a USB cable, the Windows Update installation failed. Solution You can manually install the driver. Make sure you follow the steps in the order given to reset your printer, remove the product, restart your computer, and then manually install the driver. Step one: Turn the printer off and then on
  1. Disconnect the USB cable from the printer.
  2. Turn the printer off and then back on. Clear any blinking lights or error messages.
Step two: Remove the product from Devices and Printers
  1. Click the Windows icon (c01319360.gif ), and then click Devices and Printers .
  2. Right-click the product icon (c01813941.gif ) representing your HP product, and then click Remove device . Follow the on-screen instructions to complete the process. (If the product is not listed, skip to Step three: Restart your computer.)
  3. If multiple icons exist for the product, remove them all.
  1. Restart your computer. You might want to bookmark this page so that you can quickly return to it.
  2. Make sure your computer has a valid Internet connection by opening a web browser and surfing to an Internet site.
Step four: Manually install the driver
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon (c01319360.gif ), and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Click the Windows Update button and wait for the updates to complete.
  8. In the Install the printer driver window, under Manufacturer click HP , and then search for your driver under Printers . If the driver does not show up under HP, try looking under Hewlett Packard. NOTE: The print drivers are displayed by their series names, which means the last one or two numbers may show as zeroes. For instance, the HP Photosmart 8750 displays as HP Photosmart 8700, and the PSC 1210 displays as the PSC 1200 series.
  9. Once you find the appropriate driver, plug the USB cable back into the printer.
  10. The Installing Device Driver Software window should briefly display in the bottom right corner of the computer screen. Wait for it to disappear.
  11. Click the Cancel button on the Add Printer window.
  12. The newly installed printer now shows in the Devices and Printers window.
Jan 05, 2011 | HP PSC 1210 All-In-One InkJet Printer
I installed Windows 7 (previously had VISTA) on my 32 bit VAIO, reinstalled my HP Officejet PRO L7580, installed new drivers from HP site, everything installs, but scanner won't save PDF to laptop, it just...
Hi There,
It's the quiet little war between Windows and HP you're in the middle of. HP has updates that are specifically designed to alleviate this problem, but sometimes they don't show up automatically right away after the install. So, you need to go to the HP listing in your Start Menu in all programs and see if you can update from there first. Failing a link for that there, look to the HP Solution Center that would have loaded with the full version software.
Sometimes, also, and install may just not "take hold" properly. When this is the case, you need to uninstall completely and reinstall the printer.
1. Uninstall the printer from the Control Panel and restart the computer
2. This is very inportant. HP leaves temp files even after an uninstall that will defeat and corrupt a clean reinstall unless removed. So, after reboot, hold down the WIndows Logo key on the keyboard and press the R key. In the "run" window type %temp% and your temp files folder will appear. Select all items in the folder and hit the delete key. Allow Windows to leave the files it says are in use (skip them). Close the temp file window.
3. Reboot your computer with the printer NOT attached. Run the install software and only attach the printer when prompted. Complete the install.
4. Seek out and install any updates for HP and run WIndows update as well.
This exact order is what I use professionally, and it has not failed me yet.
Best Regards
Sep 03, 2010 | Computers & Internet
Replaced old laptop with new HP-dv8t running Win 7 pro. Downloaded and installed HP Photosmart 2600 software for 64 bits. HP Solution Center says printer is not connected but I can print, scan. Under...
windows 7 install software for any printer automatically
i use hp 2100 and hp 1608 printers with windows 7 without installing their software
if your os is not recognizing the printer than you need to download theupdated software compatible with windows 7 of your printer
Feb 05, 2010 | Computers & Internet
I am trying to install an HP PSC 1210 all in one printer. When I run the installer it tells me a newer version is installed and then stops. I have tried uninstallingand using the hp Scrub program but...
Go to control panel >> Add/Remove Programs and you should remove everything that is related to the printer installation. It should remove any software conflicts with the old installation.
Then repeat installing the driver again.
Sep 10, 2009 | HP PSC 2210 All-In-One InkJet Printer
Cannot install printer hp670c completely
what file ?
and what version of windows are you running ?
Nov 20, 2008 | Office Equipment & Supplies
Driver not working
Just as a try- set up a new printer like this Start/printers and faxes/install new printer When you get insert CD or select from list Take Select from list. select then Canon in the makes list and then the model from the model list. Click install See what you get. It is possible you will get the printer only and no scanner - I do'nt know, But try it.
Jun 28, 2007 | Canon SmartBase MP360 All-In-One InkJet...
HP Officejet 100 Mobile Printer Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
