Question about Refrigerators
Fridge and freezer stopped working but fridge light still on should the orange switch by the light be on or off don't know if that is the defrost button
  • Refrigerators Master
  • 4,654 Answers
Sounds like a motherboard or defrost control board. Can you tell me the model number found inside the fresh food compartment or around fresh food section door frame, Without the model number it is hard to guess what the switch is that you are asking about, Thanks Sea Breeze
Posted on Dec 08, 2012
SOURCE: Fridge not working
Fridge not working,regulator is under repair.can u suggest the services in hyderabad.
Posted on Feb 18, 2008
aborcass
  • 2651 Answers
SOURCE: Freezer stops working for no reason
sounds like a defrost issue, see if theres a wire diagram id ck your heater/defrost circuit
Posted on Feb 24, 2008
Illeagle
  • 525 Answers
SOURCE: proline pc178a fridge freezer still
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided.
http://www.repairclinic.com/0088_4_1.asp#Level1_1
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Unfortunately, we can't describe all of the possible problems and repair solutions here. If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
  • 42 Answers
SOURCE: Fridge freezer has stopped working
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Posted on Jul 02, 2009
SOURCE: Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Posted on Jul 08, 2010
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
My whirlpool refrigerator/freezer is not cooling. lights come on, fan comes on...don't hear compressor coming on, not sure. coils are clean (they are in front). Don't know what to do next.
Switch off the fridge for few hours then before you you switch on check the continuity of the main power cord to the compressor which comes thrrough the main relay. Now the relay is activated by the thermostat/pressure switch/defrost timer.
So you will be able to trace the path of the power to activate the compressor. however if the relay clicks and shuts off the the capacitor must be checked or replaced. However if there is a heavy drain of current- use a clamp tester meter- the compresssor can be a suspect.
Please check this link for a idea of the parts.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2/278/identifying-fridge-freezer-parts.html
Sep 06, 2011 | Refrigerators
My maytag fridgerator has suddenly stopped getting cold. My freezer is fine and stays cold. Troubleshooting it did not work. Please help.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Jul 30, 2011 | Maytag MBF 2256 Bottom Freezer...
Model # bx2255w Amana Refridgerator bottom freezer works but refridge isn't cooling any more. Is it time to retire our approx 15 year old fridge or is there an easy fix?
If you have high humidity or the door gets opened a lot, the evaporator coil may need a good defrosting. There are defrosting devices in the unit like the timer, heating coils, thermostats that could be bad. There should also be a small fan in the freezer that transfers the air to the refrigerator section. If that's not spinning only the freezer will work.
If you find the fan and it's working you can do a thorough manual defrost by removing the food, unplugging the unit and letting it set for a day with the doors wide open. Have some big towels handy :)
After a day, plug it in and see what it does (don't add food, yet). If it cools down then you will know that the compressor is still good and it's worthwhile to fix.
Easy fixes: Timer and fan.
Moderate fix (cheap part - more labor) - Defrost thermosat
Pain in the **** fix: Defrost heaters.
Ed
May 22, 2011 | Amana Refrigerators
Power and light is on but my fridge and freezer does not get cold
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this will help in solving the problem.....
May 18, 2011 | Refrigerators
I have a Maytag PBF2255HEW refrigerator. It won't get cold and I just installed a new control board. When you shut the door and reopen it, the fridge and freezer control shows nothing, but if you...
Step 4 - Volt Test
May 08, 2011 | GE GDS18LBR Bottom Freezer Refrigerator
Fridge is warm, freezer works.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Maytag MSD2651HES fridge not cooling freezer works find
  • possible causes:
Jul 06, 2008 | Maytag MSD2650HES Stainless Steel Side by...
Top fridge on this model
  • possible causes:
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
222 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
