Question about Refrigerators
Galaxy model # 106.55122700
The ice maker seems to overflow at the furthest point from the water feed. I often find an iceacle from the ice maker to the already made ice and there are usually sever ice cubes stuck together as a result. What can I do?
  • Refrigerators Master
  • 4,654 Answers
The problem you described is most times the=> 2188778 Water Inlet Valve
on the ice maker side of the 2188778 Water Inlet Valve What happens is the valve turns off electricall but the mechanical part of the 2188778 Water Inlet Valve leaks ozzing water by the valve while off like a leaky faucet. The solution is to replace the water control valve. I will be here to answer any questions you have Thanks Sea Breeze
Posted on Dec 08, 2012
SOURCE: no water for ice maker
make sure wire is in down position this is like the on and wire up is off
Posted on Jul 14, 2007
SOURCE: GE GSS25LGM Ice maker
Our Ice maker quit working. Won't make ice, but will dispense water. I unplugged the refrigerator and plugged it back in. I noticed that the green light on the ice maker is now blinking. It was steady on before I unplugged the fridge. Any ideas?
Posted on Feb 12, 2008
  • 3 Answers
SOURCE: Ice maker feeding too much water and overflows
I have the GE Profile TFX24PR that exhibited the same symptoms. I had water leaking, making ice in the bottom of the ice bin, as well as under the ice bin. I also discovered ice down the back wall of the freezer.
A technician replaced the ice maker, which did not solve the problem. He put the original back and replaced the valve on the back. That too did not solve the problem. I took matters into my own hands.
I discovered that the ice maker water fill tube that comes in through the back of the freezer wall was leaking. Water would run down the outside of the tube. Some of the water would go into the ice maker, some would go into the ice bin and some of the water would also run down the wall of the fan housing where it passes through a hole in the fan housing. The big problem was the water running down the wall of the fan housing. From there it ran onto the cooling coils, where it would freeze, causing the freezer to go into extended defrost. My freezer and fridge would warm up and I had some food spoil.
If this looks like it may be your problem, you may want to enlist some help for this; it is tedious, time consuming and requires working in the confined spaces of the freezer.
After disassembling the fan housing I was able to access the fill tube. It just pushes in and is prone to wear, especially after fourteen years. I just reversed the ends of the tube and pushed it back in for a snug fit. You may want to consider using a sealer. Everything is working fine now; lots of ice in the bin, and no stray ice or water.
Posted on Apr 03, 2009
bobicehouse
  • 1524 Answers
SOURCE: Roper Ice maker wont kick ice cubes out of tray.
Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
Posted on Apr 27, 2009
SOURCE: ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Posted on Jul 23, 2009
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
Ice maker leaking water into the ice bin
If it leaks steadily you need a new water valve that feeds the ice maker. If it only overflows when it goes through a cycle, then the timing is off in the ice maker, and will need to be replaced, or adjusted. If it is adjustable, it will have a screw with a spring on it with a +/- symbol by it, behind the front white cover plate. You will just simply tighten or loosen the screw, to make the metal rod around the screw go into the - area. If it is not adjustable, there won't be the adjustment screw and it will need to be replaced. Also, sometimes its not overflowing, and it is just leaking from the mold, which also means you need to replace it.
Jan 27, 2015 | Refrigerators
Seems like my icemaker overflows when filling. I have an ice build up around the plastic box. How can I adjust water
There is not an adjustment. The ice maker dump arm has a cam on it that engages the water fill switch. switch is bad or ice maker motor has a bad spot in it .
Jun 19, 2014 | U-Line Icemaker
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker is overflowing
If water continues to flow slowly after filling the water control valve for your model will need to be replaced=> 241734301 Water Inlet Valve
If ice maker simply over fills and then the water turns itself off then this points to a problem with the ice maker=> 5303918344 Ice Maker Assembly
I will be here to answer any questions you may have, Thanks Sea Breeze
Jul 12, 2012 | Kenmore Refrigerators
Ice-maker water overflowing into the freezer/ice-maker.
Possibly the inlet valve.  If it doesn't shut all the way off it will drip water which will freeze in the chute and cause it to overflow.
Dec 19, 2009 | Sewing Machines
WP side-side freezer appears to be overflowing the
You just need a new water valve for this unit. Call us with your midel number and we'll be sure to get the right part out to you right away! We look forward to hearing from you soon.
Oct 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker seems to be overflowing with water
check for a ice blockage inside that fill tube that sits in the ice maker.
Jan 10, 2009 | Refrigerators
Nov 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker over flows with water
There is an orifice that controls the water flow to the ice maker . If to much water is being fed to the ice maker it will result in an overflow. You may want to check the pressure of the water system in your house.
If the overflow is being caused by a continuous feed to the ice maker your electric valve supplying the water may not be reseating after it shut off electrically. If this is your problem obtain a new valve assembly to replace it.
Apr 30, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
145 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
