Question about Kingston 8GB ss 4 SDHC B) Media
Repair ureadable pen drive
My pen drive is unreadable please help me , anyone with the repaing s/w if any
  • Kingston Master
  • 27,725 Answers
W7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start You might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive then you restore it to its default status Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 you might have to alternate doing this repeatedly until the problem is resolved Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
if you need more help with this or if i have missed the problem post a reply Hope this helps.
Posted on Dec 08, 2012
No space found in my pen drive
your pen drive has bad sectors.Try repairing it by typing chkdsk x: /f /r (where x is the pen drive) at the command prompt
Dec 29, 2013 | Transcend (589307) Media
4 gb jumptwist
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
Dec 22, 2013 | Sony 4GB Memory Stick PRO Duo Memory Card
Moserbaer pen drive repair
Nov 25, 2013 | Electronics - Others
DEVICE NOT ACCEPET FORMAT
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
Aug 22, 2013 | SanDisk Cruzer Electronics - Others
What do you do if it says in a game this disc is unreadable
If you have this you just need to stop the heat getting to the 2 main chips and the drive you can do this at home or send it in for a fix
Jul 12, 2010 | Microsoft Xbox 360 Console
My windows say that my pen drive Driver is outdated please update
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
May 09, 2009 | Transcend (589307) Media
Unreadable
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
2. Format pen drive
Nov 17, 2008 | Imation 10PK NEON POP OUT EMPTY (41412)...
Kingston 8GB ss 4 SDHC B) Media Logo
44 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
jairo sanchez
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
