Question about Samsung Galaxy Tab 7.7 P6800 3G 16GB Unlocked GSM Tablet Silver
My samsung galaxy tab wont charge
My galaxy wont open when i press the reset button, the battery has a 75%. when i tried to charge it, i got an error, it wouldnt charge
  • Anonymous Mar 18, 2014
    galaxy tab will not charge
  • Anonymous Mar 23, 2014
    it has a charged battery
My samsung t210 is not resetting i have tried button and inside setting options both look like its working but when reboots no change the accounts come back aswell
Before performing the Hard Reset:
- In case your Galaxy Tab 3 7.0 can connect to a computer, Then it is better to make a backup of your saved data using Samsung kies software, You can read this Guide to learn how.
- But in case that is not possible, Then you can check that your phone's battery has enough charging level, Otherwise you should charge it.
Samsung Galaxy Tab 3 7.0 SM-T210 and SM-T211 Hard Reset Steps:
- Turn your Galaxy Tab 3 off.
- Take out any existed SIM or memory card.
- Wait for 10 seconds.
- Press and hold the Volume Up key + Home key, Then press the Power key.
- Keep pressing the keys until Samsung logo appears,Release all keys.
- Wait until you get Factory reset / System Recovery menu on screen.
- Use the Volume Down key to select Wipe Data / Factory Reset option.
- Use the Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use the Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
New Hard Reset / Factory Reset Method Using Odin3 Flasher:
In case you cannot put the Samsung Galaxy Tab 3 7.0 Into Recovery Mode for any reason, Or the Normal Hard Reset operation does not solve your problem, Then you can use this new method to Hard Reset the device so easy, This New Method will reprogram the User area, And it can solve many software errors too, Just follow the steps below:
- Download and Extract Samsung Galaxy Tab 3 7.0 Hard Reset File ( SM-T210 ' SM-T211 ).
- Download Odin3 flasher.
- Put your phone into Download Mode.
- Run Odin3.exe
- Click on CSC button and Select the Hard Reset file.
- Connect your phone to PC via USB cable, And wait until Odin3 detects the phone.
- Click on Start button and wait until the operation done.
- Now your Samsung Galaxy Tab 3 7.0 will be rebooted.
- Done.
Jun 02, 2016 | Samsung Tab Tablets & eReaders
How can I get my Samsung Galaxy Tablet to turn on. The battery is fully charged.
There is usually a method such as holding the on button for a longer period of time. If it is easy to do the other thing that I've found with all sorts of "smart" devices which turn "not-so-smart" is to remove the battery for a minute or so, then put it back in. Many times the unit will turn on as soon as the battery is reinstalled and work correctly again after that. Last ditch effort, unless someone knows about the Galaxy, is a hard reset, there may be a reset button somewhere on the unit, I don't think the Galaxy has a reset button. If the unit still does not turn on it may need servicing.
1. Try the on button for 15 - 20 seconds if you know it is charged
2. Try charging for an hour or two then the 15-20 second hold on button, #1 above.
3. Removed battery (I'd measure the battery voltage while I have it out) wait ~1 - 2 minutes & reinstall the battery. If it doesn't turn on by itself try #1.
4. Nothing works start a service ticket with Samsung, URL:
http://support-us.samsung.com
You might try searching there as well for an answer to see if there's anything I missed.
Jan 31, 2015 | Samsung Galaxy Tab Tablet PC
Why wont my Samsung Galaxy Tab on 3 Mobile Tablet PC charge
either your battery is shot as in dead or your charger is faulty
you could try to charge it using a usb lead in your computer or another usb port to see if that works , or try another charger to eliminate your lead /charger you are using
Aug 01, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
To many pattern attempt
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
Apr 15, 2014 | Samsung Galaxy Tab Tablet PC
I had a samsung galaxy tab GT-P7300 , the problem is its a password protected and i have forgot the passwoed, so kinly help meout
Mar 07, 2014 | Samsung Galaxy Tab Tablet PC
To many patten attempts
Feb 10, 2014 | Samsung Galaxy Tab 2 7" 8GB Android Tablet...
Samsung tablet 7.0 will not turn on
Note: These steps clear data from the device. SD card data like your photos and music are not erased unless you choose to format the SD card.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Upuntil the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. PressHome to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
If you have access to the OS, you can also perform a hard reset in Settings.
1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
Sep 13, 2012 | Samsung Galaxy Tab Tablet PC
Galaxy tablet has frozen
Try the Reset button first - on the side...small hole. use paperclup with end extruded. Press in and hold down, turn unit on, release. If this does not work you will need to starve it of all power. no AC and remove the battery. Keep disconnected for at least two minutes. Reinsert the battery, fully charge, the turn on.
Jun 13, 2011 | Samsung Galaxy Tab Tablet PC
Hi guys, during upgrade I did something wrong. So, now I have on screen of my tab logos of pc and mobile with triangle in between. No charging, non responding, no hard reset available. Please, help...
Have you tried the hard reset? Try these instructions for a hard reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
Mar 02, 2011 | Samsung Galaxy Tab Tablet PC
The screen has frozen in e mail and i cannot switch off or move to another function or do anything
If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Menu
mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything
Dec 07, 2010 | Samsung Galaxy Tab Tablet PC
Samsung Galaxy Tab 7.7 P6800 3G 16GB Unlocked GSM Tablet Silver Logo
979 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
