Question about Neff Refrigerators
My neff k4254x4gb/02 isnt cold the fridge and freezer isnt working its on but not set
The fridge freezer appears to be on but isnt cold and isnt freezing it is warm the temp light in the fridge is flashing not at a fixed temp and is warm
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Posted on Oct 04, 2008
  • 2418 Answers
SOURCE: Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Posted on Mar 10, 2009
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Posted on Jun 21, 2009
SOURCE: Fisher & Paykel Fridge Freezer E402B beeping when door closed
see http://www.fixya.com/support/t675116-refrig_e402bre
Posted on Oct 06, 2009
Neff /freezer K9625X1GB/02 Water in bottom of fridge section
There is often a small drain channel in the rear of the fridge for defrost cycles. The drain in yours is blocked with a jelly like bio-mass. Just clean it and put a dessert spoon of bleach down it.
May 23, 2018 | Neff Refrigerators
I have a Neff fridge and Freezer Model K4204x6GB03. The fridge is getting very cold and building ICe on the back wall of fridge and too much Ice on the bottom of the fridge under the vegetable tray
First, try turning down the temperature control on the fridge incrementally and see if that gradually over time helps. If not, you may need to unplug the fridge for 15 or so minutes, hope it will recycle and then plug it back up, setting the control to what would be normally considered to be a moderate setting. If that fails, call a fridge repairman who you trust, , ,
Jul 28, 2017 | Neff Refrigerators
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Jan 17, 2016 | Neff Refrigerators
Neff K3965 side-by-side American: Freezer works but Fridge doesn't any more, 3 days after defrost
Can you remove the freezer rear panel again and take some photos of the frost pattern so I may see what is stopping the cold airflow to the fresh food section?I'm here on Fixya if you have questions
Contact Me Here
Appliance 911 Sea Breeze
Nov 23, 2015 | Neff Refrigerators
?Compressor not working
It appears that the capacitor needed to start the motor is failing and the motor is going into over heat mode . If it is outside you may get it replaced but if it is inside the sealed unit then it will be a new unit.
May 13, 2013 | Neff K9524X4GB
NEFF K4663 fridge. the freezer works ok but refrigerator space does not go below 9deg C even at highest setting. have defrosted and water drain is clear.
The defrost board is not functioning properly.;
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Neff Refrigerators
Freezer working fine,but the fridge dose'nt seem to be working not cold at all.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 12, 2011 | Neff K9524X4GB
Our fridge is making noise and this morning seems to be not working at all Items in fridge are not cold and freezer seems to be thawing out is that the end of our fridge and it is only about three years...
Most likely the defrost timers bad, manually advance the timer until it clicks and compressor should run, if not compresor may be bad, Google for defrost timer location and method to advance it, some are circuit boards and must have the door switch rapidly closed /opened a certain numbers of times or sequence.
Nov 01, 2010 | Neff K4254X4GB
Fridge/freezer . freezer ok but fridge not working even tho light comes on
check damper control, also check freezer side, if there is frost built up it could be 3 things, 1. cold control, 2. heater, 3. thermostat.
Jul 02, 2009 | Neff Refrigerators
Refrigerators Logo
51 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
