Need pinout for input cable (audio) for panasonics 2006 Subwoofer SB-WA930
Schematic or wiring diagram would take care of this for me
    Champion:
  • 208 Answers
fcollingwood
  • 58 Answers
SOURCE: subwoofer
Most AV receivers do not have a built in amplifier block to drive a subwoofer, and merely provide the subwoofer output channel at line voltage. Thus, a powered subwoofer is required. Does the subwoofer require mains power? From your description, I'm guessing it doesn't. If not, it does not have a buit in amplifier, you will need to purchase a monoblock amplifier, which is just a mono amplifier with a volume control, no tone controls or anything else. Make sure that the amplifier power rating is as close as possible to the subwoofer power rating, as it is quite possible to blow a speaker by using an amplifier whose power output is too low, by overdriving the amplifier , and putting DC through the voice coil when the amplifier clips. If it does require mains power, it will have an amplifier built in, but does not have line level inputs.
Posted on Sep 14, 2007
CLUEPATEL
  • 138 Answers
SOURCE: subwoofer cuts out
Its due to the damaged pin in which you r inserting the subwoofer pin!
Posted on Dec 08, 2007
SOURCE: connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Posted on Jan 07, 2009
    • 6 Answers
    SOURCE: I have a s108sp subwoofer
    Hey there houleo!
    If your subwoofer has a stereo input and stereo outputs, then it's a good idea to send the signal from your receiver to the sub, then out to the other speakers you have hooked up. Some subwoofers will take the low frequencies out of the signal to the left and right speakers, so that the sub handles it alone. This often gives a nice crisp sound.
    Reciever/amplifier
    l l l l V V Subwoofer l l l L------> Right speaker
    V Left speaker
    If this helps you out, I'd appreciate if you rated me well :) If you've got any more questions, feel free to ask! Cheers! -The Chicken
    Posted on May 26, 2011
    SOURCE: wiring assignment for plug of Panasonic SB WA340
    my woofer lost the sound I.C how can i solve this problem?
    Posted on Sep 22, 2011
    Can a panasonic SB-WA930 Sub be linked with a special adapter to an Akai DHT300 DVD Receiver
    If the 930 is similar to the 310 you might want to check this video out. Best I can tell they have the same connector in the back. If you a bit handy in fabricating a wire harness to fit the pins, or maybe pick a harness up off ebay and cut off the end that does not go to the sub, you probably can get it going. There are companies that will maike up "special adapters". Generally they are expensive.
    https://www.youtube.com/watch?v=NPLot7tNZ7A
    Nov 25, 2014 | Panasonic Audio Players & Recorders
    Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
    I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
    May 27, 2009 | Panasonic SC-HT930 System
    Need to connect panasonic sb wa730 to panasonic sa dp1 system
    There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
    Feb 28, 2009 | Panasonic SC-HT730 System
    I need the schematics for panasonic sb-wa733 active subwoofer
    Have you tried manualsparadise.com or eserviceinfo.com or even partstore.com. Any of these might have a service manual. Good luck.
    Jul 31, 2008 | Audio Players & Recorders
    Sc-ht500 system cable
    You cannot wire this system separately, since it is very difficult to separate the power cables from the others which carry the audio parts.if in any case , lets suppose, you could wire the dvd player separetely, you will have no audio since all the audio frequencies are transfered in this cable to the sub woofer and from there to the satellite speakers.
    It would be useless to wire it even if we could as there would never be any audio, only video, no matter what disc you use as the only way the audio is comming is throught this system cable to the subwoofer. Actually its the worst idea to implement in a home cinema system, but well, this is old panasonic.. :)
    Aug 11, 2007 | Panasonic SC-HT500 System
    HK395 Speakers/Subwoofer Cable
    Jul 26, 2007 | Dell HK395 Computer Speakers
    299 people viewed this question
     Grubhead
    Grubhead
