Question about Hoover S3614 Vacuum
Vacuum trouble My vacuum turns on but will only run if I am moving it across the carpet. It worked fine yesterday. It won't run on bare floor either.
4 Suggested Answers
  • 126 Answers
SOURCE: loss os self propel and suction??
Your belts are worn out. These belts should be replaced once a year.
Posted on Jan 20, 2008
  • 181 Answers
SOURCE: Carpet/Floor Switch problem on Hoover WindTunnel Vacuum
Well, you have to deal with it, you have to play with this electrical things if you want to fix this problems.
The good news is, the sources of the problems is the switch already broken.The first things before you do anything is, find this switch on the market first to changes the old ones.Then, remove the power cord from the outlet of course.
After have it, then you must open the old switch, and remove it from the unit by cutting the cables using cutter/ pliers or anything.But remember, you must remember the locations of each cable that been cut, you can use Camera Cellphone to make sure of it if you like.
Then put the cables back together with the new switch, after all done, clean all the mess and try operate it.
Hope it works!!!
Posted on Dec 09, 2009
Testimonial: "I got into the switch area and found that it has a clip at the end. I reset the switch and it's working better. I'm sure I need to replace soon. Thx!"
  • 141 Answers
SOURCE: I have a Hoover S3630
does your vacuum have an adjuster knob on the front? if so try raising the unit so that the brushes don't bind up on the rug and burn out the belt
Posted on Dec 28, 2010
  • 17970 Answers
SOURCE: The carpet/bare floor switch does
Turn it over, remove the plate over the brush roll, remove the cover over the intake hose. There are two screws, one on each site, remove it and, using a flat blade, there is a slot on each side, from the bottom, push it in to release it and then the top will come off.
here can find some similar guide (with pics): t3681318-expose_switch_test
Also, here could find additional and generic details: replace-upright-vacuum-cleaner-belt.
Hope helps.
Posted on May 03, 2011
0 characters
1 Points
Riccar vacuum 8625 vacuums the floors;but does not seem to have suction for the carpets
The belt may look fine but could have lost elasticity. Stretch belts will lose elasticity and should be replaced at least once or twice per year. If the brush strips are worn or frayed it will not pick up properly.
Mar 01, 2015 | Riccar Vacuums
Eureka Optima Lightweight suction weak on bare floor, hose only works when dial is turn to floor?
I think it is normal. My favorite setting is the dial is turned to bare floor. If you set your vacuum to hose, then you need to adjust the height (do not set the dial to the bare floor).
Feb 21, 2014 | Eureka Vacuums
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
The bare floor/carpet switch moves on it's own from bare floor to carpet all the time.
I'm sorry to hear you're having difficulties with your DC07. When you have your brush control set to 'Carpets', the brushbar should run when the cleaner is reclined into the vacuuming position, and shut off when you stand the cleaner upright. When you have the brush control set to 'Hard floors', it should remain in the off position until you change it manually back to 'Carpets'.
If it won't stay in the 'Hard floors' position during use, it's probably best if you get in touch with us directly so we can determine if there's a fault, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Dyson Online Customer Support
Oct 22, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Henry brushes seem to catch in the carpet when pulling-will the brushes soften and make it easier to use as it makes the head bounce of the floor a bit when pulling making it harder work to vacuum?
There is a "see-saw" type switch on top of the cleaning head (the part that you push across the floor). This raises and lowers the brushes according to the type of floor you are vacuuming. Move this switch to the other postion and you will find that it runs over the carpet more smoothly.
Nov 05, 2010 | Henry Vacuums
Brushes don't spin
Hello :
try this please : switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
or try this also if the above suggestion didn't work :
Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
please rate !
May 07, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
My brush bar won't turn - works in bare floor mode, but carpet brush won't turn when it should...
replace the belt the belt sounds like its worn or stretched the belts turn at high rpms and get very hot and soon just ware out they work fine on floors but when it comes to carpet they slow down, i hope this works out thanks
Nov 30, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Way too much suction
Did you call Dyson?  Just call their customer service and see if there have been other complaints like yours.  I just got the same model and will be looking out for this.
Dec 02, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Works on carpet not on bare floors
It's not supposed to rotate on bare floors
Nov 14, 2008 | Dyson DC14 All floors Bagless Upright...
Hoover S3614 Vacuum Logo
21 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
