Question about Neato XV-11 Robotic All-Floor Vacuum System, 945-0029
Wondering where I could obtain a schematic for my neato xv-11 all floor vacuum system.
  • Neato Master
  • 18,391 Answers
My neato signature xv says the brush is stuck. I have removed the ends and and there is nothing in the brush. The brush moves freely in the housing. It has been repaired twice for the same problem
Have you checked the belt to see if there is any damage, or if it has come loose? There is diagnostic software created by a Neato user that is available for download at robotreviews [dot] com - in the Neato forum. With this software (which runs on a PC while connected to the Neato via USB cable) you may be able to find the root cause.
Mar 01, 2017 | Neato Vacuums
My Neato XV-12 runs for only a few seconds and stop. The message says, please dust me off I cant see. I have dust and cleaned my neato and it still says the same thing. How do I fix this problem?
Hi Guys
I've fully dismantled my Neato XV-21 to locate the source of the "can't see" problem. (And also replaced a tight wheel Motor causing a "something is caught in my right wheel" message)
There several screws underneath the Neato XV-21 that must be undone to allow the top to be separated. A bit of a pain just to get into the visual sensor area. But not too hard with an electric screwdriver.
There is a Laser device & a Photo sensor mounted to a black plastic rotating wheel which is covered by a black cap with 2 holes in it. One hole for laser beam to exit & one to pick up return laser light return data. They are both rotated by a motor & pulley via a rubber "o" ring which could slip, break or get hairs caught in it.
These could be the source of problems. Once mine was cleaned & checked I had no more problems. Then the wheel motor got tight. Replacing the motor fixed the problem. This requires hoping the Motor Gear Box assembly out by poping the pivot shaft out of it's plastic holder. Then disconnect the spring & cable connector. But you bust be prepared to carefully remove the magnet off the motor shaft (vice & 2 flat blade screw drivers) then unsolder the small PCB at 2 points. With practice (twice) I can now replace a motor in 20-30 minutes.
Hope this Helps some Neato Users out there
Cheers
Trevor
neato-xv-12-runs-only-few-seconds-stop-qnpe3nojpvl4vx0tieerofmg-2-0.png Wheel Motors Here
Wheel and brush motor for Neato XV 11 XV 12 XV 14 XV 15 XV 21 XV Signature...
Apr 05, 2015 | Neato Robotics XV-12 Vacuum System - White
GET AN XV-21 FROM GOING HAYWIRE IN CORNERS
I suggest you remove power from the unit completely, including disconnecing the batteries. Reconnect and voila!
Feb 23, 2015 | Neato XV-21 Pet & Allergy Automatic Vacuum...
My neato is showing a message :my vision was blocked. please press ok (3000). How do I fix this?
Dust off your drop sensors. Using a cotton swab, clean the two drop
sensor windows on the bottom of your Neato Vacuum. Power cycle the unit, removing the batteries if necessary. You should be good to go.
Sep 26, 2014 | Neato XV-21 Pet & Allergy Automatic Vacuum...
Green light but won't start
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Jun 14, 2014 | Neato 945-0041 XV-21 Robotic Vacuum...
My XV 11 Vacuum keeps on bringing up the message " My vacuum is stuck"
This message generally means that the beater/brush bar is not turning. Try rotating the beater/brush bar manually to see if it can turn freely. If not, you will need to remove the beater/brush bar and ensure that it is clean; that the orange end caps on the brush are free of hair and dirt, and that the bar housing area is free of obstructions.
Note, when I said "beater/brush", it could be either/or, depending on whether you're using the "standard" beater bar, or the upgraded pet brush.
May 31, 2014 | Neato XV11 Vacuum
Why does my neato xv-12 keeps saying "put me on the floor" but it is and I cannot turn off
There are sensors in the wheel housing that let Neato know whether it is being held (wheels protruding from the frame), or whether it is on the floor (wheels tucked into the frame). If those sensors are not working, you will need to have the unit serviced (if under warranty), or you can look up information on how to correct the problem yourself (if out of warranty). This information can generally be found by searching the Neato Robotics forum at:
RobotReviews com
May 11, 2014 | Neato Vacuums
Where can i buy replacement side brushes on line for x500 robot vacuum
Try a site called www.ereplacementparts.com. They carry parts for stuff I never heard of.
Nov 12, 2013 | Neato Robotics Neato XV-21 Pet & Allergy...
Neato XV-11 Robotic All-Floor Vacuum System, 945-0029 Logo
373 people viewed this question
Top Neato Vacuums Experts
richie46
ray gallant
Are you a Neato Vacuum Expert? Answer questions, earn points and help others
