Question about Toshiba TDP-S8 Multimedia Projector
My TDP-P75 toshiba projector keeps cutting out for no reason - any advice anyone?
I've tried using it on different PC's and it cuts out after about five minutes - everything seems to work OK.
    Champion:
  • 208 Answers
Hi, Cutting out after 5 minutes sounds like an overheat fault. On every projector will be a filter that is user serviceable - it will most likely be blocked up with lint. To Clean - locate the filter & remove carefully. gently brush the lint & dust off the surface of itusing a soft brush or vacuum cleaner on its lowest seting. Try not to puncture the filter element. reinstall.
Posted on Dec 08, 2012
  • 7 Answers
SOURCE: Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Posted on Apr 06, 2008
Marrie
  • 563 Answers
SOURCE: Toshiba projector switching itself off
Hi 123d
Have you tried resetting the lamp timer ?
If you have and it didn't solve the problem , take out the lamp and check for any discolouration or markings on the lamp.
If you do find anything out of order then the lamp would need replacement.
Posted on May 21, 2008
  • 4 Answers
SOURCE: Toshiba tdp t45 dlp projector broken segmented colour wheel
23125963 is the Toshiba part number. Expect to pay about $65 on line. Google is your friend!
Posted on Jun 24, 2009
projdoc
  • 2237 Answers
SOURCE: Toshiba TDP-SP1 Data Projector Pink Tint
go into menu and make sure input is computer and not rgb component. or just reset to factory defaults.
Posted on Jul 30, 2009
  • 23 Answers
SOURCE: Replaced bulb in projector and it still doesn't
Smetimes the other fan comes on when set to full bright. As your lamp is not lighting up, the other fan will not come on. If yo have replaced the lamp and it is still not working, then 9 times out of 10 it is will be the ballast.
Posted on Jan 21, 2010
Toshiba TDP-P5, used unit. Startup image comes up ok. When PC is hooked up, the image does does not change from startup. Cables test okay on other projectors, the video port on the PC is working ok on with...
Try pushing the source/select button to make the projector look for a source. It is the button that looks like a bent arrow right in the middle of the 4 arrow buttons.
Jan 14, 2011 | Toshiba TDP P5 Multimedia Projector
I have a toshiba projector TDP S 20 it starts & automatically Light goes off in Couple of minute \r\ni don't understand what is the problem \r\nlooking for help
hey mike. thereis no glass in there no bulbs havebeen smashed in it, gaz what do you mean i need a sub d connection between pc. im using the vga. also it doesnt have a usb port on it and whats a pj lol. thanks guys
Nov 11, 2010 | Toshiba TDP-S20U Multimedia Projector
I have a dataprojector, no signal
Then 'No signal' or 'unsupported signal' messages are usually because your display is set too high. To see if this is your issue, hoop it back up too your computer & set the computer to the basic VGA resolution. Assuming you are using windows, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes, then drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector.
Note for Laptop users-- By default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue <fn> button (on the lower left of the keyboard, usually to the left of control <crtl>) and tap the bleu button you just found. Let go & give you
Nov 14, 2009 | Toshiba TDP-S81U DLP Projector with...
Is toshiba TDP-S8 good projector because I bought it today for $ 300.00 used. Thank you
Toshiba's s8. Designed to deliver stunning images in breathtaking XXL format, the TDP-S8 features 2000:1 contrast, the latest DLP technology for brilliant color and sharpness, and 2000 ANSI lumens brightness for top performance. The product retailed for close to two thousand dollars. Due to problems production was discontinued. If it works for you then you got a good deal. Replacement parts are easily available on ebay.com for reasonable prices.
Jul 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba tdp-mt800
Hi there
Have you tried using another input like the Component instead of the DVI. See if it makes any difference.
If not it could be the DMD or your Mainboard.
Most of the time it is the Mainboard - Home Theatre Projectors come out with awesome DMD's , so I doubt it to be the problem.
Hope this is usefull !
Aug 08, 2007 | Toshiba TDP-MT8 DLP High Definition Home...
Toshiba TDP-S8 Multimedia Projector Logo
110 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
