Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Oven does not work; no buttons on touch pad work
The touch touch pad on our 2005 Jenn-Air dual fuel down draft slide-in range has not been working for three months. Jenn-Air set up service through A&E Factory Service. They tell us we need a control pane (not a control panel), which is not available anywhere in the United States and will only begin to be manufactured this month. We have not had use of our oven for three months. Still waiting and so discouraged.
5 Suggested Answers
SOURCE: jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
Posted on May 30, 2008
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Posted on Jan 06, 2009
  • 254 Answers
SOURCE: Our jenn air model js9860aab control panel buttons
no.. u must replace the touch pad assrmbly that whole unit.... i think u have a jds9860aab i believe... the part number u would need would be 74005750 it is for sale through sears at $272.00... u might need service.. u can take a look at part at repairclinic.com just type that part number in. ohhh also i believe this is a backordered part so most companies would prob take 2-3 weeks to get soo hope this helps..
Posted on Jan 28, 2010
richroth
  • 9472 Answers
SOURCE: I have a jenn-air electric down draft slide in
You will need to replace the control board (clock assembly) on your unit. I see this all the time with power surges and it takes the control board out. Your model is a discontinued one and the part may need to be a special order. Here is a link to the part, call the number that is on the page and I am sure they may get it for you.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-clock-item-number-ap4088717.aspx
Posted on Nov 08, 2011
JAL69692002
  • 334 Answers
SOURCE: Hi I have a jenn-air 30inch slide in down draft range..it is about 15 yrs old..the oven quit working..the top works..and ideas
need a volt meater and check votage to heating elament ,most of the time food gets spilled on them and they go out ,you can find the parts easy enough
Posted on Dec 05, 2011
Dec 05, 2011 | Jenn-Air SVE47100 Slide-In Electric...
Jen Air Convection oven keeps giving a F3 error code and F1 error code
F1
Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common
problem. Refer to F1 test at the top of this page for more
information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor
(RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Dec 07, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Our jenn air model js9860aab control panel buttons on the panel do not respond--is there a rebuild kit available to repair this -- because without these buttons, the convection oven of this duel fuel range...
Jan 28, 2010 | Jenn-Air JDS8850 Dual Fuel (Electric and...
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-Air Wall Oven up controls don't work
you have a touch pad issue, whats the model and serial ill look up the part for you, sometimes you can just get the key pad, sometimes comes sa a whole console or as part of the electronic control itself.
Mar 17, 2008 | Jenn-Air SCE30600 Slide-In Electric...
I have a Jenn-Air slide-in range with a gas top and electric oven. I have tried to clean the gas grates without much success. I have also tried to clean my white exhaust cover for the down-draft. It has...
i would NOT recommend putting grates in oven while self cleaning, dont even leave the racks in there!!!! ammonia supposedly cleans them pretty good, get yourself a plastic garbage bag and a measuring cup full of ammonia. place the grates in the bag and stand the cup up in the bag with them, close the bag and place on the back stoop over night. the FUMES do all the heavy work you rinse off under the sink.DO NOT pour over the grates but stand up the cup next to them.make sue to seal the bag as well!!!
Mar 08, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Jan 14, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-Air 48600 touch button problem
Hey Erik,
Thats was happening to my sisters jenn aire just a couple monthg ago. I ordered a board for it but, the daybefore it came in I jauseled the front of the board attachment piece and made sure all connections we're tight... yada... in the maint field... you know hand search all connections with these printed led boards you can just have a loose connections and send bad signals and false board readings. And yes, even touch pads willact weird. So good luck, worked for me!
Pete
Dec 22, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
304 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
