Question about Sony MUTEKI HTDDW1600 Theater System
Sony MUTEKI HTDDW1600 Theater System how to unlock video 2
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Why does my Sony Muteki
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 01, 2011
Sound output failure
It can be many different issues; too many to go into on this website. It is most likely DC Offset, meaning a damaged amplifier. Please contact me directly at AUDIOSERVICECLINIC.COM for more information. You may contact me directly through the website.
Thank you,
Dave
Mar 19, 2014 | Sony MUTEKI HTDDW1600 Theater System
Protect subwoofer showing on power amplifier
Check your owner's manual for a Factory Reset, or Return to Default. Try that first. If it still doesn't work, try disconnecting the sub completely, and see it that resolves the issue.
Feb 03, 2014 | Sony MUTEKI HTDDW1600 Theater System
When 5 connect my ps to the blueray it tells me unlock so what do i do its frustraighting plz help .. a
Please check all your audio settings. Are you trying to connect the audio output on your Play Station to your Blu Ray, or are you trying to connect your PS to an AV Receiver? You may contact me through my website ay AUDIOSERVICECLINIC.COM.
Thank you, Dave
Jan 12, 2014 | Sony MUTEKI HTDDW1600 Theater System
Sony Muteki 7.2 USB Fail error, no USB plugged in
Sony Muteki with USB Fail message or turning on and off is generally related to a faulty mains input relay. Search for it in the schematic and replace with a stronger part. Sony uses a very weak relay to connect the mains after power button is pressed. It doesn't last too much.
Sep 19, 2013 | Sony MUTEKI HTDDW1600 Theater System
My wife says that the muteki 7.2 chanel does not need to be going all the time um something todo with the over useage of power so how do i just run the tv without the muteki going as it wont go meani
You can turn off the 7.2 channel surround sound system if you only want to listen to audio on the TV channels, you may need to increase the volume levels on the TV.
Use the 7.2 channel surround sound when you want surround sound when playing DVD movies.
Jan 10, 2013 | Sony MUTEKI HTDDW1600 Theater System
Will the Muteki sub amp work with a different receiver that has no trigger.
My subwoofer recently burnt out because I had it plugged into a different amplifier.. I wouldn't recommend it. Sony has released the sub to suit that system.. Do keep in mind that I did have bass boost on with the sub up full (Which didn't matter when I had it connected to the Sony amplifier..).
Proceed with caution.. I would recommend turning the sub down and using the sub volume control on the amplifiers settings to change the volume.. Just do not run it at a pace where it looks like it is stressing.. When I say stressing I mean, looking like it is going to jump out of the enclosure..
-Dubkingz
Aug 17, 2011 | Sony MUTEKI HTDDW1600 Theater System
I try to connect my BD player with HDMI port cable from BD player to Sony HT-DDW1600 Theater and from this receiver to TV (40? bravia). When I press BD button on the remote, picture comes out very good but...
Is your sony receiver HDMI pass through? some receivers dont allow audio just video through HDMI. Connect a digital coaxial cable from the dvd to the receiver and you should get true dolby surround.
Oct 28, 2009 | Sony MUTEKI HTDDW1600 Theater System
Protection
sounds like you may have your speakers connected wrong or too many speakers. Check all your speaker wires for a goo tight connection and speaker compatibility with your Home theater system. Hope this will help you
Dec 20, 2008 | Sony MUTEKI HTDDW1600 Theater System
Sony MUTEKI HTDDW1600 Theater System Logo
109 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
