Question about Hotpoint Ultima WF860 Front Load Washer
Wt960 child lock stuck
The child lock button is on - the door will open and shut but I cannot operate any other button. I have tried everything including turning the machine off at the plug , but still cannot get the child lock off. Any suggestions welcome
gittos73
  • 244 Answers
SOURCE: Door Lock
right ther are 3 solutions that u can do 1)take your drain hose place it low to the ground into a bucket this should reset your pressure switchn if not goto solution 2 2mark were the cable is with black marker in case u need to put it back were it was if this does not work ull need to unplug your washer for this 1 undo the screws at the back top to take off your lid now if there is a cable to your motor u need to take a small black clip of were the cable goes into a holder u wont be able to c it ull have to feel for it once uve got this of click the cable up once and once done check the door to c if it will open now do this until it opens if not goto solution 3 3)if u feel do the front of the washer on the inside of the washer u need to be on the left hand side were the door latch goes into the catch by feeling down u will feel were the cable goes into this assembly godown slightly more and pull up the door should open on its own without having to push the switch let me know how it goes i am a hotpoint specialist m8
Posted on Aug 28, 2007
  • 8 Answers
SOURCE: child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
Posted on Jul 30, 2008
SOURCE: hotpoint ultima 840
hold child lock button down for 2 seconds you will then hear a beep done.
Posted on Sep 17, 2008
  • 100 Answers
SOURCE: Hotpoint WF865 Child Lock Button Stuck 'On'
you should be able to turn it off by holding it in for a while longer,5-10 seconds, unless the circuit board is at fault.
Posted on Jan 28, 2009
SOURCE: how do you remove the child lock off the washing machine
Great Thanks for that
Posted on Apr 20, 2009
My back door in 2004 Ford focus child locks are locked and I can't close my door. How do I disengage the child lock to close my door?
Your latch may be stuck in the latched position. Try pulling on the handle as to open the door while lifting the latch arm.
Jul 31, 2015 | Ford Cars & Trucks
How can I release chid lock on hotpoint ultima wt960
The Child Lock button is the second from the right in the line of buttons below the LCD screen. Press and hold this button for at least 2 seconds (or until you hear the beep and the icon light goes out). With a number of appliances, I've found that it takes longer than indicated to release a child lock so hold the button until you hear the beep.
The manual for the Ultima WT960 is available here: http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf . See the bottom of page 18 for the child lock toggle information; the picture of the washer option buttons is on page 9. Use the Adobe Reader Zoom to see the keys (at step 5 of the Starting a typical wash programme). Other Hotpoint appliance manuals are available here: http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do .
If the lock will not release, then you may have a problem with the keypad or the controller.
I hope this helps.
May 10, 2012 | Hotpoint Washing Machines
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
The child locks are stuck it only opens from the outside
there is a slider switch on the door(between door and frame) that you can lock or unlock the child locks to prevent them from opening the door from inside but still can open door from outside----just slide the lock switch to enable or disable the child lock.
if they are stuck/stiff---you may have to remove the door panel for repair.
Usually they work free with a liitle lubricant(WD-40) to slide easier.
Jan 23, 2010 | 2000 Ford Expedition
CHILD LOCK STUCK ON
I agree with the initial solution, depress the child lock button for at least 3 seconds.
If it does not clear, then try again.
Good luck.
Please rate my solution.
Thanks.
Feb 12, 2009 | Hotpoint WMA74 Front Load Washer
Child locks won't release
1997 ford explorer awd child safety won't open from the inside can you help
Nov 12, 2008 | 1997 Ford Explorer AWD
Child lock light stays on - & cant start mc programmes
Jul 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
