Question about Fujitsu LifeBook N3410 Notebook
I have a Fujitsu N-series N3410 laptop. I want to slide my 4GB SDHC card into the media card slot on the left side of the computer. It plugs into place alright but then the computer does not recognize it. In fact, nothing happens at all. It is like I did not put anything into the slot at all. Is this a driver issue or something else?
  • 275 Answers
Na i dont think there is a driver issue try with a known working card and see if it does the same thing is yes than there is issue with the reader if the other card works its issue with the card which is not working
Posted on Jan 12, 2009
I Have absolutley no idea where to plug this product in at on my laptop.
If your laptop is less than 5 years old, you should have a SD card slot on the side of it, which is about the width of a postal stamp. You need to plug your microSDHC card into a "SDHC to SD card adapter" first, then you plug the whole thing into the SD card slot. Otherwise, you need to buy a card reader that takes a SDHC/Transflash card directly, then you plug its USB plug into one of the USB sockets on the side of your laptop.
May 22, 2011 | SanDisk 4GB microSDHC Memory Card
I have a fujitsu lifebook model no N3410 that needs a restore disk that I can not find. Where can I get one to restore this computer?
If you're pertaining to the restore disc that came with the laptop, you need to contact Fujitsu to request for it.
Hope this helps.
May 20, 2011 | Fujitsu Siemens LIFEBOOK N3410 PC Notebook
It will not format a 4gb SanDisk SD card
Your 4GB card is actually an SDHC card. The DX6490 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with SD cards 2GB and smaller.
Nov 28, 2010 | Kodak EasyShare DX6490 Digital Camera
Can not read sd cards. The blue light goes on after introducing the SD card in the slot (the small one on left side), but "My Computer" does not show the folder even after refreshing.
Is you're card a SD HC (High Capacity) Card (usually > 4GB)?
Some older readers dont read the HC cards, if so the solution may be to buy a usb reader that will read SDHC cards.
Oct 27, 2010 | Toshiba Satellite M30 Notebook
I got a new 4gb sd memcard for my 2005 canon ixus 50, screen shows " memory card error" "card locked". tried switch on card as u suggested, no diff.
The IXUS 50 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Oct 06, 2010 | Canon Cameras
Where do i put it in my lap top
It depends on whether your laptop supports SDHC, microSDHC, or neither.
1. Supports MicroSDHC: check on the manual the position of the MicroSDHC slot.
2. Only supports SDHC: you need to purchase an adapter - essentially a full-size SDHC with a slot where the MicroSDHC goes. Plug the micro card in the adapter, plug the adapter+card into the SDHC slot.
3. Neither: you need to purchase both a micro-to-SDHC adapter and a SDHC-to-USB reader (usually SDHC in supported in most "XYZ-in-1 readers", like Quanta 32-in-1 USB reader - check out "SDHC USB reader" in eBay, for example).
Feb 11, 2010 | SanDisk 4GB microSDHC Memory Card
Sansa e260 doesen't detect 4gb micro sdhc card
I will have to double-check the documentation that came with that specific MP3 player, but I know that some Sansas will only support upto 2 GB in the expansion slot.
Jun 09, 2009 | SanDisk Sansa e260 MP3 Player
Pavilion zd8000 digital media
tryt o inser your 4gb SD memory card in other device, see if the sd card is good ? otherwise, your laptop's flash ard-slop NOT SUPPORT SDHC memory card (4GB OR BIGGER is SDHC)
Dec 27, 2008 | HP Pavilion zd8000 Notebook
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read -
Mar 03, 2017 | Computers & Internet
Additional memeory
You might be running into a problem with the new card being a SDHC (Secure Digital High Capacity) card and not just a SD (Secure Digital) card. I have had similar problems with SDHC cards when I put then in older products that have regular SD slots (Photosmart Printer). The cards will still fit into the slots, however the method as to which they are read and written to is different which causes the problem. So, maybe try updating computer hardware drivers or mp3 firmware from the Sansa website. Also, if you can, exchange the 4gb SDHC for a 4gb SD card, this could be a pain in the ****, but this solution should fix your problem definately. Hope some of this helped.
Aug 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Fujitsu LifeBook N3410 Notebook Logo
243 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
