Question about Panasonic KX-T7730 Corded Phone
Zero Rings during meetings
how do i set the phone straight to answer machine?
  • Panasonic Master
  • 2,460 Answers
With either a Do Not Disturb (DND) or Call Forward all calls command. On a TA-824, DND is set up with the command 714# on the intercom. It will light the DND button. It's cleared with 710#. There is no function to the button, ie you can't push it on and off. If you have voice mail, you can set it to forward all calls via the 711 (vm ext) #. It will blink the FWD/DND button.
As an aside, 7341# stops paging to the phone. 7340# brings it back. Again, these are TA-824 commands.
Carl
Posted on Jan 15, 2009
How can I get the phone to ring when an outside call comes through instead of the recording?
It is an option in the menu under phone settings. If number of rings before answering machine is not set to a number or set to zero it may always go to the answering machine.
Sep 16, 2015 | Lands Phones
My phone does not ring, it goes strait into message.
This is probably due to settings on the answering machine part of the phone. Either get out the user manual and go through the setup menu or go to whatever the manufacturer's web site and download the user manual there. Then go into the settings and either turn the ringer volume up from muted or change the number of rings it rings before answering the call to more than zero.
Jan 26, 2015 | Lands Phones
Hi. When my house phone rings more than three times my fax machine trys to answer the phone making conversations inpossible. How do i get my fax hp1040 to answer only my fax's?
The fax is set to answer on the 4th ring. Change it to answer on say... 6 rings.It cannot differentiate the call before it's picked up ... it just answers at at set number of rings
Apr 01, 2011 | HP 1040 Plain Paper Inkjet Fax
I want to change the message on my answering machine. Manual lost
I changed the message, but now the phone rings and rings and does not pick up message, and displays "minus sign" not zero. Pls help.
Sep 16, 2009 | GE 29875GE Digital Answering Machine
Unable to put phone in silent in times of need - samsung j700
press <Menu> → Settings →
Phone settings → Phone profiles.
You should see different profiles such as Normal, Outdoor, meeting, etc. Choose the one you want to use. You can change the rings for each of these profiles by selecting the one you want and choosing options/edit.
Apr 21, 2009 | Samsung J700 Cellular Phone
"i have a uniden 6 0 dect2080 3 answering machine how to check the messages from a different phone"
The default security code is "80". If you have not reset that code, you will use 80.
This is all from the manual:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about ten rings and sounds a series of beeps.
2) During the greeting or the beeps (if answering system is off), press 0 (zero) and enter your security code within 2 seconds.
3) The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero" followed by a beep.
Then the manual lists all the remote commands. If you need those, you can go to uniden.com and download a manual.
Apr 13, 2009 | Uniden DECT 6.0 Cordless Phone ID
How to set hp1040 fax to work with aout answering
If you are using the same phone line as your fax, you can start by connecting the answering machine on Line2 or 2-Ext at the back of the fax. Set the fax to answer on two rings higher than the Answering Machine. (for example: if answering maching is 4 rings, fax is 6 rings)
And then, turn on the auto answer.
Mar 22, 2009 | HP 1040 Plain Paper Inkjet Fax
How do I retrieve my voice mail when I'm away from home?
this instruction may help you , if not a model number could help , but try these instructions . thanks
To operate from a remote location, use any touch-tone telephone, and follow these steps:
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 57).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following chart:
Remote Commands
Command 0 then 1
Repeat a Message*
Command 0 then 6
Answering Machine On
Command 0 then 2
Playback Messages
Command 0 then 7
Memo Record/Stop**
Command 0 then 3
Skipping a Message
Command 0 then 8
Greeting Record/Stop**
Command 0 then 4
Deleting a Message
Command 0 then 9
Answer Machine Off
Command 0 then 5
Stop Operation
Command 1 then 0
Help Guidance
we can get a link to your manual if we had model number
Dec 30, 2008 | Uniden 5.8GHz Dual Cordless Phone
How to retrieve messages from the answering machine ..remotely
Remotely Operating Your Answering Machine
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
Apr 01, 2008 | Uniden TRU9488 Phone
Setting the number of rings to answer
Press "Mute" to setup handset, select "Ring to answer", here are 1,2,3,5,6,L choice. you can change to 3.
Dec 16, 2007 | GE 28112EE2 Cordless Phone
Panasonic KX-T7730 Corded Phone Logo
329 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
