Question about Sewing Machines
I toke the cutter off of my Brother 3034D serger to clean behind it. When I re-attached it th machine will still serge however the cutter won't work. What do I need to do
  • 3 Answers
SOURCE: Where can I find sheap part for 1034D brother serger?
Find a sew & vac shop near your house they usually have sewing machine parts
Posted on Jun 16, 2008
SOURCE: Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at knowgodnofear@bex.net
Posted on Oct 28, 2008
  • 15 Answers
SOURCE: How do I dis engage the cutter
What does your manual say?
If the 1634 is anything like the 1600 I don't think you can disengage it. I have the book for the 1600 and there is nothing mentioned about disengaging -- only changing the blades. Some models are like that. You might join the White serger group and ask the members there..
http://groups.yahoo.com/group/white_model_sergers
Someone may have an answer or a way around it.
Otherwise, all I can suggest is to call or go to a Joann's or a Husqvarna Viking sewing machine dealer and ask them. Alternatively, a sew and vac repair shop may be able to assist.
Posted on Oct 31, 2008
SOURCE: Baby Lock Serger Thread keeps breaking
Mmmm...., maybe NOT the solution, maybe, just a key.
I have a copy of theBaby LKock EA-605 instruction booklet in English, Germann, French and Spanish. NO ideas how it casme into my orbit, but happy to pass it on.
Posted on Mar 06, 2009
SOURCE: my viking serger 905 wont cut
Sometimes the blades need to be adjusted. Lower them all the way manually to the bottom. The cutters if you look on the side should meet. If they don't' meet or if there is a small space then the upper cutter needs to be lowered.
There are screws that hold this in place. You might need a man to help since the screws on my machine are very tight!
Posted on Apr 10, 2009
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
How do I adjust the seam allowance to cut 1/4 inch
Hello
To the right of the cutter, on the front cover, there are markings indicating various seam allowances. Placing the fabric edge along the specific seam allowance will automatically cut off the required amount of fabric and the serged seam will be on the seam line. Do a test sample first to ensure that the marked lines refer to the left needle or to the single needle that you are using.
Yes, there is a blade position dial too. It is located closest to you on the left side on the bottom. The larger the number, the wider the seam. Again make a few test samples to ensure the results that you are seeking.
Happy stitching.
Sep 10, 2014 | Brother 1034D Serger Sewing Machine
Does anyone have a suggestion? I have threaded the machine correctly but I cannot get the machine to sew.
You have a nice serger, so let's start with some basics:
Is your serger cleaned?
Go back to the instruction book and set the entire machine to the factory settings. For example, set all the dials to tension 4. Use quality thread which is made for your spool holder. Usually cones of thread work best. Use an appropriate fabric, not sheer, not very heavy drapery fabric. Make absolutely sure it's threaded properly. Finally, make sure all the threads are under the presser foot.....then start serging. If the serger still won't serge without tangling, it might be good to have it serviced. I find that buying a new serger is more useful than having a worn out one serviced. Good luck!
May 05, 2014 | Brother 925D Serger
Brother 1034d serger. Seems unusually noisy (mechanically) in needle/cutter area. Not motor or belt as noise is metal parts clacking even after new needles, cleaning, oiling. Is this sound normal for...
in response to all serger, no, after my babylock serger is cleaned and serviced it runs quietly.
as for the brother, it's possible thats normal, try contacting a repair shop in your area and tell them about the serger and see what they say.
it's possible that the serger may need some type of adjustment
or a part may have broken .
Sep 06, 2013 | Baby Lock Eclipse Serger
Brother 1034d handwheel stuck
the best thing to do is take the machine in to have it checked.
sergers are nice & very useful, I have a babylock serger with the jet-air
looper threading systerm, and I use it alot when making clothes.
I even used my serger to serge the ends of fabric that I haven't used yet
so the ends won't fray.
Jun 11, 2012 | Brother 1034D Mechanical Sewing Machine
I have a Husqvarna serger and when I try to serge and cut through 3 thicknesses of sweatshirt fleece it won't cut. I have replaced the cutter and it still won't cut. The same happens when I sew on polar...
I really need to know what kind of serger you have , if it is the 905 910 or the 936 series take a look at the large headed screw that holds the knife in place. if you are doing fleece it will cause a lot of build up of lint behind this screw and not allow the knife to go all the way up and down causing it not to cut multi layers of fabric, and if this is the case it probably needs to go the an authorized tech for a thorough cleaning
Oct 21, 2009 | Husqvarna Huskylock Computerized 905
My simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
Mar 18, 2009 | Simplicity Serge Pro SW432 Mechanical...
Sewing Machines Logo
42 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
