Question about Beverage-Air DD58 Beverage Cooler
Beverage air dd58 kegerator won't stay cold
I have an older model bev air dd58 kegerator 2 tap stainless steel model that won't stay cold. I have had the freon charged twice in the past four months. It stays cold for about a month and then gets warm. The unit keeps running and won't cycle off and it won't drain at all. Any advice?
  • Anonymous Mar 21, 2014
    I have an older Beverage Air DD58 kegerator. I am replacing the condensation tray. To do this I had to pop up the top. My question is how do I now seal it when I put the top down? Can I use silicon? If so, is there a special kind I need?
  • Beverage-Air Master
  • 1,252 Answers
The freon system is a sealed system. If you are adding freon, there is a leak. have the leak repaired and this should resolve the issue. Freon should not need filling but one time and only after the leak is located and repaired.
Posted on Jul 11, 2010
  • 122 Answers
The unit is probably low on gas again. If it lasts a month the leak may be difficult to find, as it may be a small leak. Those units don't hold a lot of gas. Have someone do a nitrogen leak check and fix the leak. If no leak is found, have them install a UV dye to help find the leak. :)
Posted on Sep 23, 2009
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
Resealing lid on a Beverage Air DD58 kegerator
The only way I have found to seal those tops back down is with 100% silicone caulk, NOT LATEX OR BUYTAL, silicon.( We use 3m.) Then hold it down with cinder blocks for at least 24 hours then you are in business.
Mar 21, 2014 | Beverage-Air DD58 Beverage Cooler
I have a Bevair DD58 and it won't stay cold. I
the three weeks kinda tips us off to a leak in the sealed system
check your sradder valve for a proper seat
and make sure your joints are clean and complete
Oct 13, 2009 | Beverage-Air DW49 Stainless Steel Beverage...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Beverage air cycling off/on
These units are not designed to run in temps much lower than 50 degrees. They have no winter controls and the freon pressures will take a nose dive when running in a cold ambient condition. The unit will not run well in a cold environment, compressor damage may result. :(
Dec 16, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Beverage air dd78e not cooling
change setting on thermostat and see if anything changes. If yes, that's the prob if no, freon level. start there.
Dec 14, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
With the BevAir DW49 does a lower number mean colder or warmer?
1 is usually the warmest setting. The higher the number to colder the setting. Start in the middle and make minor adjustments allowing considerable time in between to dial in the temp of your unit.
Dec 04, 2008 | Beverage-Air DW49 Stainless Steel Beverage...
Restriction
The cap tube is clogged and the unit is overcharged. Get used to this on beverage air units.
Nov 18, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Beverage-Air DD58 Beverage Cooler Logo
880 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
