Question about KitchenAid K45SS Classic Stand Mixer
Mixer doesnt turn trying to take top cover out how do i do that?
  • dba3 Jan 17, 2009
    Same problem -- it doesn't turn. The motor is running. And I can't find any resources online to help me figure out how to take the machine apart -- not even books I can buy.
  • 10,865 Answers
On the web type this into your browser
there you will find your machine, a parts list and an exploded diagram. Sounds line the evans sensor needs to be replaced. good luck
Posted on Jan 18, 2009
Kitchenaid mixer will not start
The model number shown is for the Professional series which does not have a separate rear cover. Below are links to KitchenAid mixer Service Manuals:
Professional 5/6 quart
4.5/5 quart
May 13, 2014 | KitchenAid KP26M1X Stand Mixer
Hook straggles to turn when dough in bowel
The Legacy is an electronic mixer and the transmission does not have any gear, and it frequency convertor that works in phases 2 and 3. If the hook struggling when turns, check the transmission belt locasted at the top of the mixer, remove the cover first.
If the belt is loose, tense it with the screw on the base of the motor or replace the belt. If you can not fix it, let me know and I'll try something else.
Mar 23, 2014 | Hobart HL600 Legacy Stand Mixer
When I plug the mixer in it turns on immediately to the highest speed, it wont turn off unless I unplug it. The speed, control whether its on or not doesnt work.
Something is amiss under the back cover, unplug it, remove the cover and have a look. You may need a meter to test thinks but you could just as easy find something by looking. Make sure looking and touching is done unplugged.
Sep 16, 2013 | KitchenAid K45SS Classic Stand Mixer
How to I remove cover to expose control board
Turn the mixer around and face the rear of the machine, look at the round end cover; on the top center you will see a small phillips head screw take it out and then lift up and slightly out to remove the cover of the electronics of the machine, the first thing you will see is the speed control plate (black and copper) behind that is the governor and behind that at the top is the phase control board. Hope that helps, What are you trying to accomplish?
Jan 19, 2013 | KitchenAid KSM50HDPBK Stand Mixer
Grinding noise
I needed to replace the nylon worm drive in my mixer. When I put it back together, I found that my mixer made a kind of grinding noise. The noise was due to a vibration associated with the cover for the electrical wiring in the back of the mixer. I solved my noise simply by loosening the screw to this cover. The cover is located on the back of the mixer, and the screw is on the top.
Separately, to find instructions for opening your mixer, you can go to
Jan 13, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Hello i would like to know what kind of oil to use on a Hobart mixer d300 its a 3 speed mixer the problem im having is 3rd speed runs like 1st speed could it be the clutch that is bad thank you
d-300 and d-340 mixers dont use oil they use grease -47 can be bought @any hobart office. there are several reasons why this problem can happen. try tighning the planetary nut all the way then back off 1/4 TURN .also do the same with the top main shaft nut if that doesnt work contact me back
Nov 16, 2009 | Food Mixers
Motor is running, but mixer not turning
hi mary. there is a phillips head screw in the rear of the mixer head. if you turn the mixer around you will see it in the band. remove that screw then remove the other four screws that hold the top on the motor cover. good luck with it.
Jan 20, 2009 | KitchenAid K45SS Classic Stand Mixer
Breville wizz stick professional doesnt operate.
If you can feel anything when you press the button, unplug it and try to turn the mixer. Once you get it freed up, put a drom of cooking oil where the shaft comes out through the case.
Jan 14, 2009 | Food Mixers
Mixer attachment
make sure attachment is turned full counter clockwise to release point give a good tug if doesnt work try a light tapping with a rubber hammer or lobster wooden hammer
Nov 20, 2007 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
51 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
