Question about Refrigerators
I have a samsung model SR-L3626B the fridge does not get cold i have taken the panel off at the back of the freezer to expose the fan which tries to spin bu does only now and then can you help?
5 Suggested Answers
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
notsomot
  • 67 Answers
SOURCE: samsung fridge freezer not cold enough
Heya,
I did samsung warranty for awhile and these fridges have a faulty defrost termination clixon. What happens is when you turn off the fridge it turns it off defrost. If you do get a tech out there are two parts you need to fix it. One is a yellow sensor cable and the other is a defrost termination wire that is black and red. These two parts i use to sell for $70aus when the fridges where out of warrenty.
I actually have one of these fridges now and work so if you have any other problems please let me know
Regards Mat
Posted on Jan 08, 2009
  • 28 Answers
SOURCE: Hi i have a hotpoint mistral plus fridge freezer,
hi is this the frost free version ??? if it is which i think it is it could be a fault with temp module{frost free have electronic modules to control the system rather than a old fashioned bog standard thermostat inside the fridge} the fans should be controlled by the module in case of frost free models it could be the module which is playing up
Posted on Jul 23, 2009
SOURCE: SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Posted on Oct 13, 2009
Samsung sr s20 fridge freezer fan rattling
What is the model number listed on the refrigerator?
Nov 26, 2012 | Refrigerators
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
Samsung Fridge Freezer (Freezer on top) Model SR-52NXA Freezer is cold but fridge is not cooling ?
remove evrything from bottom of freezer. take out the shelves . You will see a panel on the back of the unit with screws holding it on take these off . under it is the freezer exchange coils they got froze up,
and frosted full so now no air is circulated between the cabintes, refridge and freezer do not use any sharp object to clear it use a towel and blow dryer to thaw it even a spray bottle with warm water, but don't pick at it!!!! you can puncture the coils . take your time and you will save your unit. also while your at it pull it away from the wall remove that small panel from the back, and the grill from the front and with your long reach nozzle vacuum the heat ex changer coils under the unit. put back together carefully and it will run for a while longer i have one that is a 72 model still runs great Oh any change you find is mine!
Sep 06, 2012 | Samsung Refrigerators
Samsung Model SR 21 NME. The freezer is on the top, this freezers fine, but the fridge isnt even cool. We have taken the back off the freeze to do a complete defrost. The fan works fine. But the ttemp dial...
Inside the fridge compartment, at the back, is a panel that can be removed, remove the screws careful with the bulb, its plugged in behind the panel.
the panel has a vent that allows cold air flow from the freezer, this will often freeze completely shut with ice. let it thaw out, then check to see that the vent opens, or closes when you turn the dial, the best thing is to open it as wide as possible, I even used toothpicks to open the valve even more, its just a thin flap, surrounded by Styrofoam.
afterwards if your fridge is too cold, adjust the real thermostat located in the freezer.
Jan 06, 2011 | Samsung Refrigerators
Freezer is cold but fridge is warm
check door seals for freezer and fridge. If ok, check frost level in the freezer. Ice present on the back of the freezer panel (evap cover) remove evap cover and check for defrost problem by ohming out heater and defrost thermostat. If both check ok, then test the defrost timer. If this unit new and covered under wty, call a&e factory svc at 1-800-905-9505 for a free repair. consult your owners manual for wty details.
Jun 25, 2009 | Sanyo SR-1030W Top Freezer Refrigerator
A.
Feb 28, 2008 | Refrigerators
Fridge not cold enough
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting, YOU CAN TRY turning FREEZER CONTROL To A WARMER FREEZER SETTING Allowing.. MORE AIR.. to refrigertor side.
Sep 25, 2007 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
