Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
2 Lan ports not picking up cables
The 2 lan ports on the back of my computer no longer light up when a cable is inserted into either of them. This is after three rapid shutdowns of the computer. Could the rapid power surges have short circuited the 2 ports but left the rest of my motherboard unharmed? Need help to get the 2 ports working again.
    Genius:
  • 1,269 Answers
Try to uninstall and reinstall the driver for the LAN cards. You can also try to remove it from the motherboard, change PCI slots then reload the driver.
Posted on Jan 12, 2009
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
Belkin F5U307 Hub suddenly doesnot work on my Macbook
The lights (link light) on the hub indicate the LAN cable from the computer to the hub is connected and working.Disconnect the cable fron the hub and the computer then connect the Lan cable to the computer first and the other end of the LAN cable to the hub anf the link light for that LAN port on the hub should light up. If not the LAN cable could be faulty then try a different LAN cable.
NEXT
Try turning off the power to the hub for 30 secs, reconnect the power and check the LED lights. If this does not fix the problem then it appears the hub is faulty.
Apr 20, 2012 | Apple Computers & Internet
Do I need the power cord to my D-Link router to set up my computer?
From the port marked "Wan" on the back of the D-Link, install a lan cable to the cable/dsl modem.
Insert the lan cable from Dlink port labeled "1" to the PC.
The Dlink, cable/DSL modem, and PC should all be powered on.
I believe the router comes with a CD/DVD. Insert this into the PC to set up the router.
Be sure to read through your Dlink manual for additional instructions.
Dec 25, 2011 | D-Link AirPlus DI-524 Wireless Router
Im trying to connect my modam could you please help
First step is to make sure if the modem is functional. This can be done by connecting your computer to modem and check if you are able to log on to internet.
Second step is to connect the cable which previously connected to computer to Router's WAN port not LAN
Third step is to power cycle the modem and router that is power off and on both modem and router
Last step is connect router to your computer with new ethernet cable using one of the LAN ports of the router. There are usually three or four LAN ports on Router!
Good luck! Repost if you still need help!
Sep 06, 2011 | Computers & Internet
I have ibm R50e ... i insert the lan cable .. Light turns on but my network card .. Pci modem and many ither things are not installed and i can find the drivers not even on ibm site
Hi, Here you can find all the drivers for your computer: http://www-307.ibm.com/pc/support/site.wss/MIGR-55042.html
Please note that usually network card does not requires drivers for Ethernet port - Your network might eventually be defective if all drivers installed does not fix the issue.
May 20, 2010 | IBM ThinkPad R50e Notebook
Connecting inteface with computer- lan port
The LAN (or Network port) is located on the back of the motherboard. When you connect the cable from the AR 161 to the motherboard, the lights will start to flash - Green = Stable and Orrange = data flashing.
Sep 23, 2009 | Sharp AR-161 Laser Printer
Lan port will not light up when ethernet cable is pluged in
The lan link light will only come on if a valid connections is made between the device and another computer.Even if the computer is turned off the link light will come on as the computer still uses some standby power, check to see if the cables are terminated correctly on either sides, that the cable hasn't been cut or badly bent somewhere, possibly try the same cable on the same port with another good device.Also swap the cable with another known good cable and try on the same port and see if the light does come on.
Aug 02, 2009 | D-Link DI 514 Wireless Router (DI-514)
Won't play back and is no longer recognised by my computer
Problem solved with my jensen SMP-1GBD MP3 player. I re-examined the instructions & followed them exactly as they were written, then the unit worked just fine. What I found out was that you first have to plug in the ear phones, then you have to hold down the "on", button for three full seconds before it will turn on. It was just a case of not following the proper procedures as written on page four under the "Power on/off ", section of the directions.
Dec 31, 2008 | Jensen SMP-115 MP3 Player
Out of 4 networked computers, 1 computer has stopped networking, and the light on the Linksys for computer #3 confirms this because it's light is out. How do we fix this?
It could be one of two issues. The cable has gone bad. Replace the cable. Or, the LAN port on the computer has gone bad. Replace the LAN port. If it's a built in LAN port, just add a PCI one; they can be purchased for under $10.
Jun 22, 2008 | Computers & Internet
CNET CWR-854 Wireless G problem.
hello!
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
Apr 24, 2008 | Cnet (CWR-854) Wireless Router (cwr854)
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
155 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
