Question about JVC TH-C30 System
Reciver will not come on
No power
Sony str-av1020 reciver Power supply transformer burned!
http://www.sony.owner-manuals.com/STRAV1020-service-manual-SONY.html
Aug 19, 2016 | Sony Audio Players & Recorders
I have a STR AV1020 receiver. If I leave the power cable plugged in, even if the system is off, there is an issue. When I power on the receiver, all lights come on and stay on. Sometimes playing with the...
Hello i have a Sony str-av 1020 reciver. But reciver is burned power supply transformer. At the transformer walks around 125 v, but i don't know how much Current transformer on the other side is, and i don't know what transformer i have to buy? Please help. I would be very grateful!
Mar 08, 2010 | Sony Audio Players & Recorders
Panasonic SA CH46 double cassette reciver not workimg
I HAVE A PROBLEM IN Panasonic SA CH46 double cassette
POWER SUPPLY IS NOT WROKING PLZ TELL HOW >?
Dec 24, 2009 | Audio Players & Recorders
The dishnetwork. Sighn just dances around the screen I push select and nothing happens
This sounds like this may be an issue with your tv 2, make sure your remote is in sat mode by pressingthe sat button. then select, if still nothing take your remote to the recvr and look on the back of the recvr to make sure the uhf ant. is standing straight up if not, straighten and try remote functions. if you stillg et no responce there could be other issues that are simple to fix depending on what kind of equipment you have. you can call 800-333-3474 for assistance or reply with recvr name or model #.
Nov 16, 2009 | DISH Network IR Remote Control
Power subwoofer
reciver should have came with an adapter, try google to see if you can find one
Oct 03, 2009 | Theater Research TR-502 5.1 Surround Sound...
It doesnt recive the power
Your water valve is probably frozen. Put a portable heater in the area overnight and see if that helps. you may have to thaw the pipes / hoses with a hair dryer - be careful!
Dec 31, 2008 | Kenmore 24032\24036 Top Load Washer
How do i reset my jvc tv
Either a bad lamp or bad reciver board.If audio amp ic on reciver board shorts ,it will kill part of supply and lamp ballast will not turn on and fire lamp.
Dec 28, 2008 | JVC HD-52G886 52" Rear Projection HDTV
No cb channels no audio no recive
If you have no channel display or CB operation, it sounds like a blown voltage regulator that supplies power to the CB PLL circuit.
Sep 14, 2008 | Ranger TR-696F SSB CB Radio
Send or recived fax
1st of all do check that the telephone line cord is plugged into the correct jack in the machine. It needs to be in the jack marked "line." not the jack marked "Tel."
Further questions need to be addressed, such as :Is this a recently acquired machine? or Has the machine been disconnected from the power for any length of time? or Has the machine been moved to a different location?
Dec 21, 2007 | Canon LaserClass 9000L Plain Paper Fax
Powers on but immediately shuts down
No I hate to be the one to give you the bad news but most likly the capacitors in the power supply or the output circuit of this reciver, are bad and most likly need to be overhouled. Or there is mosture contamination on the printed circuit board. It is time to let go and buy a new reciver, unless you want to invest big bucks into the repair of this reciver, as Im sure it can be repaired, but at what cost??
Oct 08, 2006 | Yamaha HTR-5250 Receiver
JVC TH-C30 System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
