Question about FocalPrice PIPO MAX-M1 9.7" Tablet
Pipo m1 max tablet sees but fails to authenticate home hub
Sees bt homehub router but fails to authenticate and connect with it
What does authentication error mean when I try to connect to my wifi?
You need to input the authentification code which was supplied with your router.
Aug 09, 2015 | Tablets & eReaders
Manual for irulu 10.1 tablet
I found a manual for Android 4.2 for a different tablet (a PiPO Max-M6 tablet) which I've never heard of, but has many similarities to the iRulu AX105. The manual has been useful to me.
Jul 02, 2015 | Tablets & eReaders
I cannot get started with the hudl 2 I have touched the screen with the bt wireless nuber but I still says authenication problem and check wifi settings
Make sure your tablet is updated on all its apps and software. If not and it has missed an update your tablet and it will show a authentication and wifi error.
Mar 20, 2015 | Tablets & eReaders
Why will my nextbook 8 not connect with my home wifi
  • Can you see your router from the tablet? If not, check to make sure that WIFI is enabled in the Android settings.
  • Does your WIFI have a password? If so, you need to enter the password in the Android WIFI settings entry for your router.
Jun 14, 2014 | Nextbook Premium 8 Se Android
Connect to ipad
You don't assign an IP address to your iPad, it has one assigned to it by your router.
Open the Settings app on your iPad. Make sure Airplane Mode is OFF. Tap Wi-Fi. Make sure the Wi-Fi switch is ON, Ask to Join Networks is ON. Your in-home wi-fi network should be visible in the list titled Choose a Network.... Tap its name and provide the network password required by your router.
If you don't see your local router listed, it may not be properly configured.
Mar 10, 2014 | Tablets & eReaders
Authentication problem
trying dumbing down the authentication on your wifi router. Try these:
turn off 40mhz wide channels
try wpa instead of wpa2
try tkip instead of aes
if all else fails, try wep.
Feb 11, 2014 | Craig CMP741d Tablet
Why does my tablet keep saying authentication problem when trying to connect to wifi
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Dec 30, 2012 | Archos Arnova 10 4GB 4)
Connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Dec 21, 2011 | Tablets & eReaders
FocalPrice PIPO MAX-M1 9.7" Tablet Logo
49 people viewed this question
Top FocalPrice Tablets & eReaders Experts
Tom Chichester
Are you a FocalPrice Tablet and eReader Expert? Answer questions, earn points and help others
