Question about Bosch Washing Machines
Bosch classixx 1200 fills, drains, but won't wash ?
Whats wrong with a classixx 1200 which fills & drains but doesn't wash ?
  • Bosch Master
  • 3,463 Answers
This a classic example of worn brushes in the motor.
To check , remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws that secure motor, and lever motor back with a screwdriver or similar.
Keep hold of the motor as you lever it back.
You will find the brushes at the terminal end of the motor, replace if less than 4=5 mm in length.
Refit motor belt and motor plug.Test. before you refit panel
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
  • Anjy Long
    Anjy Long May 04, 2014
    yes, but how do you take the actual brushes out??
My bosch classixx 1200 expressnot taking fabric softner
Okay first try removing the soap try and cleaning it,secondly get a jug of water and partly fill the softner tray, at this point it should automaticly drain if not then looks like the Solonoid coil valve is at fault quite easy to replace cost of parts around £20......Good luck, hope the first part solves this......
Feb 02, 2011 | Bosch Washing Machines
Washine machine not spinning
It sounds like a snapped belt or a broken motor. Can you here the motor run? You can access the motor and the belt from the back of the machine. If it is the belt snapped, this is easy to replace yourself. If it is the motor, you will need a repair man.
Jul 17, 2010 | Bosch Washing Machines
My Bosch Classixx 1200 has stopped rotating. The electronics seem to work, the machine fills with water and drains water away, but the drum stays still. It can be rotated by hand and the drive belt is...
Check the exit hose behind the machine, the one going into the standpipe. This should be around 3 feet up from the ground level, and then into the standpipe. It shd be about six inches into the standpipe & not too tight into it.
This hose may have fallen off, the reason why your water drains away, instead of collecting in the machine to commence a wash. The next to check is the thin tube coming up from the pump area to the pressure switch. Maybe this has come loose or there is a puncture in it.
Pl give me a good rating for the free help, if helped ie.
May 18, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 It take in water then stop. I can drain it but it will not spin.
It looks like there could be a problem with a belt, maybe it sliped off, or maybe it broke, i would look that first
Nov 04, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 wont spin at all, water fills ok even pump to drain it back out .can hear it clicking as it tries to get motor to turn
You need to check the back of the unit and there's a strong possibility that the belt is broken or slipped out of track.
Jun 26, 2009 | Washing Machines
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Mar 29, 2009 | Bosch Washing Machines
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
570 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
