Question about Samsung LN32B360 32 in. LCD HDTV
Backlight for a samsung 32 inch ln32b360c5dxza tv
4 Suggested Answers
  • 58 Answers
SOURCE: DIGITAL SOFTWARE UPDATES FOR SAMSUNG 32 INCH LCD TV
you cant force updates, and they may never be another update. updates are only made when there is a problem with the software in the tv
Posted on Mar 12, 2008
BoiseLCD
  • 63 Answers
SOURCE: samsung 32 lcd tv backlight off after 4 sec. audio
If your TV is staying on and you hear audio after the picture goes dark, then you have a problem with a CCFL or the inverter circuitry that drives them.
Most likely an inverter problem.
Like a bad xformer (usually fogged up plastic wrapper)
Or a bad cap (bulged, swollen, cracked)
Or maybe a shorted IC or transistor (test for short circuit between the different pins of the device)
Posted on Oct 08, 2009
dcramer531
  • 1654 Answers
SOURCE: my samsung has backlight and sound but no picture
More than likely, like me you have your Picture set to Dynamic mode and the backlight at 100%, maybe even DNR activated.
Here is what you do. Keep trying to turn the TV on, evertually it WILL come on, sometimes it might take 100 attempts over a couple of days. Once you get the TV to come on, do the following.
Each and every time BEFORE you turn off the LCD, change the picture back to Standard mode and turn off Digital NR and turn off DNIe, also turn the backlight to the lowest setting. The Standard mode will remember the backlight, DNR and DNIe values. You'll just have to change between Dynamic and Standard in the future after power up.
If you do this everytime you turn off the set, it will probably always turn right back on for you.
The Cause: The t-con board does not stay at 100% performance over time. It is susceptible to decay in performance due to heat damage. The t-con board runs hot to begin with, it runs hotter the more that is demanded from it by maxing out the video image settings. The t-con board also sits directly above the hot power supply and the processor on the t-con board has virtually no heat sink.
Lowering the video settings at startup allows the t-con board to function.
Samsung should probably release a firmware that throttles the video settings at startup
Let me know how this works for you so we can save you some money if possible.
Posted on Mar 07, 2011
How do I check the backlight inverter on my TV
If you wish to get some details; check the site linked here. Pull up older posts.
Sep 20, 2016 | Samsung LN32D450G1DXZA 32 In Lcd Hdtv 720p...
Samsung un40eh5000f led backlight don't work i replaced power supply and main board still no luck
Troubleshooting the Samsung LED TV Model UN32EH4003 ...
? 2:46
https://www.youtube.com/watch?v=2TImpsUnGtI
Jun 25, 2013 - Uploaded by George Droukas
Samsung TV troubleshooting, In this video you will be able successfully ... where can I buy the power supply board? the ledlight doesn't light up so it .... The second port was still fully intact but also not working, I was able to get it .... which turns onbacklight (BLU_on) and turns on the power supply (PS_on).
Samsung UN40EH5000 Review; 40-inch LED TV, (also ...
reviews.lcdtvbuyingguide.com/samsung-lcd.../samsung-un40eh5000.ht...
The EH5000 is Samsung's lowest end line in the larger size LED backlit LCD TVs for... 60Hz refresh rate doesn't handle judder sports programing and gaming as ... take advantage of the resolution, giving you more work space on the screen.
Samsung UN40EH5000 40-Inch 1080p 60Hz LED TV
www.amazon.com/Samsung-UN40EH5000.../B00723...
Amazon.com, Inc.Samsung UN40EH5000 40-Inch 1080p 60Hz LED TV (2012 Model) ... Samsung didn't advertise this (or maybe its just my TV), but I have absolutely NO BACKLIGHT BLEED...... Hope that helps you find the settings that work best for you. ..... Game Modedoesn't really do anything except make the picture darker and less ...
Jan 05, 2016 | Samsung 40-inch LED TV - UN40EH5000FXZA...
Want to see dvd hookup for model#ln32b360c5dxza want to .Picturepicture of back of tv
See this link for the manual - looks like the hookup diagram is on page 6:
http://www.manualslib.com/products/Samsung-Ln32b360c5dxza-2824887.html
Feb 08, 2015 | Televison & Video
Samsung Model LN32B360C5DXZA not receiving power.
Power converter board is probably blown.
Take it to a repair shop.
Apr 06, 2014 | Samsung LN32B360 32 in. LCD HDTV
Samsung Model LN32B360C5DXZA TV will not power on. Dead.
Check and replace damaged component/s at its main power regulator board, or, replace the board as card basis. If you wish to get more details, check this link.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 22, 2013 | Samsung LN32B360 32 in. LCD HDTV
Samsung 32'' LCD TV backlight works occasionally
Check for any loose soder points or loose connections with wiring sockets to backlight inverter board.
Apr 20, 2012 | Samsung LA32B450 32 in. TV
No picture have sound 32 in lcd
Hi! Welcome to www.fixya.com.
You most likely have a backlight issue with this TV set. Could be the inverter circuits for the backlights. The inverter is the power supply source for the backlights. there could also be a screen driver problem. This would entail changing the entire board. You should call in an authorized Samsung repair center to check this set out for you.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. God bless. Bye for now.
Jul 18, 2011 | Samsung LN32C350 32 in. TV
Why is my new samsung lcd 32 inch getting on and off again and again it self? and a voice it coming from the back part too.?
Under a year,this tv was bought?Tv still have warrenty,call Samsung for warrenty repair.Not.Tv power on have flashes of pictures,few sec.than dies,have only sound left?Yes.Ur tv have dead 1 or 2 long board call the LCD inverter boards.These 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produre a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 LCD inverter long boards for the replacement.
Aug 09, 2010 | Samsung LN32A550 32 in. LCD TV
Green light is on but screen is black
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Samsung LN32B360 32 in. LCD HDTV Logo
110 people viewed this question
Jerry Greenberg
Jerry Greenberg
