Question about M-Audio Studiophile AV 30 Computer Speakers
My M-Audio Studiophile AV 30 Computer Speakers volume control is broken. Any suggestions would be welcome, thanks
After a period of the sound cutting out when i use the volume control it finally got too bad to use. The control is a double one and controls each speaker volume at the same time. I could measure the the resistance of the tracking to find the value but need to disconnect it first. Just wondering if there is a direct replacement part out there...
3 Suggested Answers
SOURCE: I need to find out
The main speaker with the amplifier has very weak sound but the other speaker is working fine. Any suggestions.
Posted on Apr 01, 2011
pctech1
  • 1940 Answers
SOURCE: I have the M-Audio Studiophile AV 30 speakers; I
First, check your Green Audio Out Port with a working pair of headphones to ensure that the sound does work and is not muted.
  1. If the headphones work, plug in your Speakers and make sure the 1/8" Stereo cable is plugged into your Speakers Input Port, not the Headphone Out Port.
  2. Make sure the power supply is plugged in and connected to the speakers.
  3. Using the front panel switch, turn on the Speakers and adjust the volume until you can hear sound being produced.
  4. If they still fail to work, you may have gotten a faulty set of speakers.
Posted on Aug 10, 2011
My speakers keep shorting out would the power cord be a reason?
No, the power cord is not the issue. Tell us more about the symptoms
Oct 14, 2012 | M-Audio Studiophile AV 30 Computer...
Studiophile Av 20 Speaker has power but no sound
Do the level controls/volume controls move freely? or with difficulty? are the jacks correct for length and polarity? Do they "pop" when input is unplugged?
Mute button somewhere?
Jan 30, 2012 | M-Audio Avid Maudio 99005226600...
No power up on my Creative Megaworks THX 550, No light on , No sound, Thanks you
@bronk50 He said "No power up"... Useless reply !
I too have a Megaworks system and sometime after it has lost current for an extended period, it won't power up... but it does magically after some minutes. I don't remember exacty what I did last time it did start up, but it eventually got on !! My advice:
Let the sub plugged to the wall. Put the rear switch to OFF then wait 30 minutes. If it does not start up after that, let the switch ON and cycle ON/OFF after another 30 minutes.
Hope this helps! This system is underestimated... The subwooofer is so musical. Great bass comes from this system. Another hint: Keep your bass volume at 2 bars, I found it to be the sweet spot before it goes boomy :-)
Apr 30, 2011 | Creative Labs MegaWorks THX 550 Computer...
The main speaker with the amplifier on my M-Audio AV30 has very weak volume and the other speaker is working fine. Any suggestions.
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Apr 01, 2011 | M-Audio Studiophile AV 30 Computer...
Speakers have been working fine for a couple of years, suddenly cut out and im not sure if they are broken or not, have all the updated drivers, have tested other speakers so its not my sound card.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 21, 2011 | Labtec Spin 55 Computer Speakers
Working but the sound is dissorted
Check for any dust or moisture on the 3.5 mm Audio Jack that connects the speakers to the PC
Plug out it for once and plug in again after cleaning it
this should solve the problem
Feb 27, 2011 | M-Audio Studiophile AV 30 Computer...
Hello! I purchased a pair of M- Audio Av 30 speakers years ago and I've noticed that at times they emit an annoying buzzing sound from the subwoofer parts of each speaker. I normally dont notice it because...
LOL. This is a common, easily solveable problem. Remove your cellphone or anything that emits radiation of any sort from the general area. Don't believe me? send a text message while sitting net to your speakers. It does this even if you arent sending a message because your phone sends intermittent signals to the cell tower. the radiation being emitted from the phone does weird things with the magnets inside the speakers.
Dec 27, 2010 | M-Audio Studiophile AV 30 Computer...
I need to find out what amp fuses go into my M-audio studiophile AV30 speakers. please help.
Sep 23, 2010 | M-Audio Studiophile AV 30 Computer...
How does this hook up to your computer? im buying it in a package with home recording tools and im confused
connects to audio output in back of computer with 1/8" stereo jacks. also can connect with standard RCA cables but you would need to find an adapter for the back panel of the computer.
it would help if you posted more information about your system.
Nov 26, 2009 | M-Audio Studiophile AV 30 Computer...
M-Audio Studiophile AV 30 Computer Speakers Logo
32 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
SHIVAJI YADAV
SHIVAJI YADAV
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
