Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
2000SD Garage Door Liftmaster - Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
  • 11 Answers
SOURCE: Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
Posted on Jun 24, 2008
  • 5 Answers
SOURCE: Liftmaster Garage Door Opener Problems...
The problem lies in the RPM sensor, most likely due to the interrupter cup assembly. The interrupter cup assembly is the black cap that runs through the RPM sensor. You may have forgotten to re-attach this piece or it is probably moving too far out when the garage sets in motion. To fix this, remove the cup assembly, unscrew the two screws on the top metal piece with a 1/8 allen wrench, push the metal piece as far in as possible and put the screws back on. This will give more room for the cup assembly to spin and be read by the RPM sensor. Hope this helps!
Posted on Jul 10, 2008
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Posted on Jul 25, 2008
  • 3197 Answers
SOURCE: I have LiftMaster garage door model 41A3039 and
To program the keypad, first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Posted on Jul 13, 2009
  • 3197 Answers
SOURCE: my garage door opener (liftmaster 1265) buzzes
Remove the cover from the motor unit and check the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Posted on Apr 05, 2010
Testimonial: "Don0930 - Yes, gear is stripped. Will be purchasing replacement gear instead of new unit. Thx!"
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Why is it when they get old enough to start needing repairs no one responds anymore? Not just this but everything.
Craftsman (LiftMaster) Garage Door Opener Won't Open or ...
? 9:29
https://www.youtube.com/watch?v=w4bgS9_u2u0
Aug 9, 2011 - Uploaded by Kris Kasprzak
Learn how to replace stripped gears in your Sears Craftsmanautomatic ... This instructions should be good for a Liftmaster,Chamberlain, ...
Manual Disengage for LiftMaster/Sears Garage Door ...
? 1:24
https://www.youtube.com/watch?v=y6q5I_JaEoI
May 21, 2012 - Uploaded by Brandon Bailey
Manual Disengage for LiftMaster/Sears Garage Door Opener ....to Replace the Circuit Board on Chamberlain Liftmaster, Sears, and Craftsman ...
Nov 08, 2015 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door goes up and down on its own?
Liftmaster garage door goes up and down on its own when i open it
Jan 05, 2012 | liftmaster Chamberlain Garage Door Opener...
How can I make the liftmaster higher to fit my van double car garage with liftmaster professional Thanks a lot Rob
If you have a garage door that is higher than the normal 7 foot there are 8 and 10 foot door extensions available. Contact your dealer.
Aug 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Dodge Durango won't sync with my Liftmaster
In 2005 there was a radio frequency change for garage door openers. If your homelink is new and the opener is old or vice versa they will not work together.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door opener will only work at wall unit
check electric saftey beams. shovel blocking them. dirty. aligned (LED on in each unit)
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Transmitter not working ( 3 of them)
don't hold down green button. push for one second. do yu have console with vacation or lock button. deactivate it.
Dec 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
